Xpand! - Librarian Menu doesn\'t show any presets
The title pretty much sums it up. In both 1.0 and 1.0.1 (which I had to install by manually copying Xpand!.dpm) nothing but "factory default" shows up in the Librarian Menu in Xpand. Any ideas?
Re: Xpand! - Librarian Menu doesn\'t show any prese
Ummm.... mac or windows?
I'm running on a Mac and I'm still having the same problem.
Where is the Xpand!.dat file located on your system?
Have you tried running the Set Xpand! Content Location application? You can download it from the Xpand! 1.0.1 page.
• linkedin •
I have not moved the .dat file.
Also, lately I have been having a few non ProTools related mac problems I have been unable to solve so I wiped the HD and reinstalled the OS. I installed PT 7.0, updated to 7.1, installed xpand 1.0.1 r2, and had the same problem. Just to clarify exactly what I am experiencing, here is one of Scott's articles on Xpand! (with pictures): http://www.audiomidi.com/classroom/p...tcorner_16.cfm when he says "I have chosen 14 E Pianos + Clav > 03 Tremolo Suitcase" the picture immediately following shows the menu I cannot get. this menu has the numbers in it (as in "14 E Pianos + Clav"). the only item I get is "factory default." this is very frustrating, all of the voices are there, just not the presets. any ideas? |
I figured it out. It was a permissions problem. The xpand installer apparently set the permissions pretty rigid on the xpand presets folder (compared to all the other presets folder at least). I changed the owner of /Library/Application Support/Digidesign and all subfolders/files to the user I use to run protools and it seems to work fine now. Can't believe I didn't think of that months ago...
just reporting for other people's benefit |
Plug-In Will Only Show On Drop Down Menu | DJLilSteve | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-04-2010 08:44 AM |
Presets Disappear in Plug-in Librarian Selection | JB3 | Pro Tools TDM Systems (Mac) | 3 | 05-24-2009 10:48 PM |
xpand missing patch in pull down menu | nossnevs | Virtual Instruments | 5 | 04-03-2008 04:33 PM |
Can't get plugins to show up on menu | Illl0lll | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 07-16-2006 12:42 AM |
Xpand Menu Quirkiness | Zave | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 03-09-2006 02:17 PM |
