Install AAX Plugs Without Having Pro Tools 11 Installed
I have been rebuilding my music computer, and am getting ready to install more plugins than I realized I had.
I hope to buy "vanilla" PT 11 while the special is going on, but I don't have it yet. Can I go ahead and install the AAX versions of my plugins without having PT 11 installed when I install the other plugin formats? Just trying to avoid having to do another plugin install if I'm able to get PT 11. Thanks, guys... (And if you want to, you can give me a "bitchy" reply to "get me back" for the "bitchy" replies I have been guilty of giving lately!)
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
Re: Install AAX Plugs Without Having Pro Tools 11 Installed
Hey Bill
I would think you need to have PT11 installed first as the folders the plugins install into wouldn't be there until the actual software was in place This is of course only my "guess" but it would make sense in my head. Best Regards Christopher
As long as the software/plugin is compiled correctly and the directories are set right by the manufacturer (which they always have been in my experience) if the pre-set directory does not exist, it will be created for you.
So if you do not have Pro Tools 11 installed you will not have Program Files>Common Files>AVID>AUDIO>Plug-Ins as a directory/folders, that being the string that's used for AAX64 bit plugins. However, all of these folders will be created for you when you install an AAX64 plugin. This is not just common to Pro Tools plugins, the same happens for VST's even if you don't have Cubase, Sonar, Reaper, ect.... If you are installing a video plugin for Media Composer you could also install the Premier Pro or After Effects versions even if you do not have those programs and the directories will be created for you. Ect... ect... TLDR; Yes.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Thanks guys...will give it a shot tomorrow and see how it works...
First install of Pro Tools 9 - Logic 9 already installed - PlugIn install questions | b-pole | macOS | 2 | 08-31-2011 07:23 AM |
Need LE8 installed to install Pro Tools 9? | Venta | Pro Tools 9 | 4 | 12-31-2010 02:38 AM |
I had Pro tools installed once on this computer. Now I Cant Re-install it. why? | cityboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-01-2010 02:55 AM |
Installed new plugs and PT won't load | TeleKing | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-17-2009 10:06 AM |
Where are Plugs installed on Hard drive? | Gothboy | Virtual Instruments | 1 | 11-25-2006 01:19 AM |
