Old 06-14-2013, 07:47 PM
FreshPrinceATL FreshPrinceATL is offline
Default "Not a valid audio volume." W.T.F.
Ok so I have a mbox2 mini with protools 8 le. For some reason it wont let me open or create a new session. It states that i have to go to the workplace, select my hard drive, and turn it to record instead of transfer. Pro tools tells me that its not a valid audio volume so how can i fix that?? Thanks in advance!!
Old 06-14-2013, 09:27 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: "Not a valid audio volume." W.T.F.
In the worspace, next to any hard drive, you should see a button that has one capital letter:
- T = transfer (not being used for playback or recording)
- P = playback (not being used for recording)
- R = record (this is what you want to see next to your audio drive)
Janne
Old 06-14-2013, 10:23 PM
zedhed's Avatar
zedhed zedhed is offline
Firstly; You are recording to a separate physical drive right?
If you still have a problem having done what JFreak has said, look at the name of the drive you are trying to record to. If at some point you've named the drive, it must be under (I think) 11 characters. If it has a long name or has separated names, right click the drive and rename it to a one word name. I simply renamed mine 'Record'.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 06-15-2013, 02:23 AM
JFreak's Avatar
Also, be sure that the file system is a supported one. If you use Mac, be sure to use HFS+ Journaled Case-Insensitive file system (this is the selection in the Disk Utility when you format). For Windows, I think it needs to be NTFS.
This is something I always forget because I live in an Apple-only bubble...
Janne
Old 06-15-2013, 04:54 AM
I think this restriction is a Windows only thing as I've never run into that on a Mac. But on either platform there are also certain characters that while they may pass muster in the operating system in use PT has heartburn with.
Jack
QAPLA!
done all the recommendations ..still get "not valid audio volume" error anthemra Pro Tools M-Powered (Mac) 0 09-17-2011 01:17 PM
Lacie Hard Drive "not a valid audio volume" katiegrey Storage Subsystems 0 06-14-2010 10:55 AM
New supported external drive "not a valid audio volume" j4callen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-12-2009 08:53 PM
Pro Tools HFS+ / Macdrive Error "Not a valid Audio volume for recording" theaero 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-30-2009 11:13 PM
New MBox PTLE 8.0.0cs2 with "not a valid audio volume" SteveBoker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-10-2009 12:15 PM
