Old 10-13-2012, 10:30 PM
Jamie_aep Jamie_aep is offline
Default SC48 in 64 channel mode (not enough layers) question
Hey guys,
I've recently updated our touring show where I do monitors from FOH. To do this I split the channels and have a monitor 'layer'. When we're on a profile it works out that layer A/B are my FOH channels and layer C is my monitor channels. To do this I put some blank strips on the B layer to make it all neat and tidy. We come in at something like 55-ish channels all-told.
We've got some dates coming up where I'm on an SC48 in 64 channel mode. The SC48 I'm pre-prepping on is version 3, so there's enough processing power, but because of my blank channels to make everything nice and neat, it pushes the end of my monitor layer off a bit, to 'layer E', if you will, due to the physical fader difference from Profile -> SC48.
Is there any way of accessing that layer on faders? I can delete the blank strips that are on layer C, thus making it half FOH/Half monitor, but I'd rather not if theres another way around it!
Cheers,
Jamie.
Old 10-14-2012, 03:16 AM
Roland Clarke Roland Clarke is offline
Default Re: SC48 in 64 channel mode (not enough layers) question
You could set the channels on that layer to a VCA and then by double presing the associated VCA enanble "VCA spill" to recall the particular faders you need, tha's assuming that you have only 16 active faders on the monitors.
Old 10-15-2012, 09:41 AM
Sheldon Radford's Avatar
Sheldon Radford Sheldon Radford is offline
Great suggestion Roland. If all VCAs are in use the channels can also be assigned to a Group and spilled in the same way.
Sheldon
Old 10-15-2012, 10:01 AM
Greg C Greg C is offline
The exception for group spill is if your'e running in 24 bus mode. Then group spill won't work.
Cameron Pro Audio
Exclusively at the Miners Foundry
Old 10-15-2012, 08:04 PM
Thanks for the help guys.
I might end up putting them all in a group and using a function key to spill the group. (if that's possible)
Thanks again!
Strike In GM Manual Mode Channel 2 Question mrgroovy Virtual Instruments 0 05-24-2013 11:44 AM
Flex channel sc48 Jreichwein VENUE Live Sound Systems 6 09-16-2011 10:56 AM
SC48 Test (Vegas) Mode? XxAExX VENUE Live Sound Systems 2 07-24-2011 07:42 PM
Stereo Groups, Expert Mode, SC48 Limelight VENUE Live Sound Systems 1 10-14-2010 05:06 AM
DIGI 002 Double-channel mode guitarmongoose 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-29-2003 04:53 PM
