Pro Tools 10 Crashing on Startup on fresh install of windows
Hi I recently re-installed Windows 7 onto my PC and after I installed Pro Tools 10 again it's been crashing on startup. Here's an image of what's happening: http://i.imgur.com/7VCzy.png
I thought maybe it was the plugins so I removed them from the control panel and tried again but still crashed at startup. I tried running it with the ASIO4ALL drivers I used before with and without. I also tried with the tascam interface connected and disconnected. I have installed all the updates for Windows 7 including SP1. It used to work on my old windows installation so I'm really not sure as to why this is happening. I even tried the 10.0.2 update but with no avail. Any help would be greatly appreciated! Best wishes, Scott |
Re: Pro Tools 10 Crashing on Startup on fresh install of windows
Did you install Quicktime and the latest PAC drivers?
Yeah I found out that my DEP (Data Execution Prevention) was disabled. So I followed this:
Please enable DEP. Enable DEP This troubleshoot can sometimes help resolve issues with installing and launching Pro Tools software. If you have disabled this for any reason, it is often recommended to re-enable it. 1.Open the Start menu and type "cmd" (without the quotations). The Result you get should be "cmd.exe". 2.Right-click on "cmd.exe" and choose "Run as administrator". 3.Click the Allow button if it asks you for permission. 4.Type or copy & paste this into the command prompt window: bcdedit.exe /set {current} nx OptIn 5.Hit enter and you should see the confirmation: Operation Completed Successfully. 6.Restart the computer and DEP should be on for the entire system. Thought i'd share if anyone else had this problem :) Cheers, Scott |
Elastic Audio plugin Error msg on fresh install of PT 11 Windows | Justin1524 | Pro Tools 11 | 8 | 10-17-2013 12:05 PM |
windows 7 64 bit fresh install robotic playback issue | youngez3 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-23-2011 09:01 AM |
Fresh install of Pro Tools Le 6.4 | cherrancemetal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-01-2011 10:21 AM |
Pro Tools wont boot after a fresh install of windows | sammyfarr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-08-2008 09:03 PM |
HD3 Accel fresh install and crashing | kid-digi | Pro Tools TDM Systems (Mac) | 6 | 06-23-2004 07:03 PM |
