Old 02-07-2010, 05:58 PM
riprock17 riprock17 is offline
Default Triggering Multiple Instruments Tracks Simultaneously
I was wondering if it is possible to play and record more than one instrument track simultaneously. For example, I would like to be able to trigger an instance of velvet (for example) with my axiom pro, and also trigger a different instrument track running Battery with my v-drums. I can only seem to get both the axiom pro and the v-drums to trigger the same instrument track. Am I missing something or is this impossible?
Old 02-07-2010, 06:34 PM
nst7 nst7 is offline
Default Re: Triggering Multiple Instruments Tracks Simultaneously
You would need to set one of the instrument tracks to a different midi channel (channel 2 vs. channel 1, etc.) and set the corresponding midi controller to that same channel. I haven't messed with this but it should be covered in the Protools reference guide.
Old 02-07-2010, 06:54 PM
The MIDI Output defaults to the MIDI Node automatically with Instrument tracks what needs attention is the MIDI Input and that needs assigning to the sending device.
filosofem
Old 02-07-2010, 07:50 PM
Thanks guys. What was throwing me off was the "Default thru instrument" in the MIDI preferences. Once I set that to none, then everything clicked for me.
Old 02-07-2010, 08:02 PM
Even with Default Thru Instrument selected you still need to Record Enable to record.
filosofem
Assign outs to multiple tracks simultaneously brianjanthony Pro Tools TDM Systems (Mac) 8 01-20-2017 04:29 PM
How do i track multiple midi tracks simultaneously? Bambison Pro Tools TDM Systems (Mac) 1 11-04-2009 02:14 PM
Recording multiple tracks simultaneously lew742man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-29-2007 03:40 PM
editing multiple tracks simultaneously bradwarren Pro Tools M-Powered (Mac) 1 02-25-2007 07:18 AM
Recording multiple tracks simultaneously MarkPresti 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-05-2003 09:13 AM
