Old 09-29-2009, 07:56 PM
thenewnoise thenewnoise is offline
Default mono mode vs multi input mode in Audio Suite plugin?
Hello,
I'm running running Pro Tools 8 for a couple weeks now and liking it.. I see something I haven't noticed before in Audio Suite Plugins.. I have the Waves L2 open and wanted to apply some light limiting to a printed mix and I'm seeing mono mode and multi input mode... When I apply the L2 to the stero mix in mono or multi mode I can see a difference in the Waveform.. I looked for an explanation on this in the L2 guide but couldn't find it.. Anyone know what I should be using on a stereo track???
OSX 10.5.8
Pro Tools 8.0 HD
MAC PRO Dual 3.2GHz Quad- Core
8 GB RAM
EXTERNAL OWC FIREWIRE 800 Drives
2 x Digi 192 i/o 24 ins 24 outs
Old 09-30-2009, 02:02 AM
mano111 mano111 is offline
Default Re: mono mode vs multi input mode in Audio Suite plugin?
If you are applying L2 (or any dynamics plugin) on a stereo mix you should use Stereo mode or multi input. When doing so compression is applied to both channels simultaneously. This will maintain the stereo image you have created in the mix.
If you use mono mode it will apply the compression to each channel individually based on its respective content - this may lead to a distorted stereo image and some weird panning effects.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
Old 09-30-2009, 04:12 AM
Chris,
I think its
multi input mode = stereo = same compression on both cannels (what you would typicall use in your case)
mono= multi mono = individual compression for each channel
I'm still on 7.4s and I seeing L2 stereo or L2 mono. Have they chnged the teminology in 8?
Old 09-30-2009, 04:52 AM
crizdee's Avatar
crizdee crizdee is offline
Originally Posted by mano111 View Post
Chris,
I think its
Yes you're right. I got Waves multi-input and PT multi-mono mixed
Chris
Producer, Engineer,
www.ukmastering.com
Old 09-30-2009, 06:58 PM
Thanks guys! I knew I never saw that in 7.4
OSX 10.5.8
Pro Tools 8.0 HD
8 GB RAM
Does c24 do multi-mode? egyptmatta ICON & C|24 0 09-04-2012 01:54 PM
Input mode and virtual sound check mode gagaiop VENUE Live Sound Systems 1 07-15-2010 11:37 PM
Grid mode, shuffle mode, spot mode and slip mode. RogTaylor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-24-2010 10:30 AM
T-Racks 3 Deluxe in multi.mono mode (PT8) Help! jiveman Pro Tools TDM Systems (Mac) 0 01-29-2009 01:17 PM
Audio Suite crashes PT 6.4 in Preview mode HELP! JazzyJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-24-2007 03:27 AM
