Old 06-28-2009, 04:08 PM
jasonguitar jasonguitar is offline
Question How do I get rid of "Missing Files" message when PT loads?
Each time I load a particular session in Pro Tools M-Powered (7.3.1cs7), I get the following message: 2 Audio files, 0 Fade files, and 0 video files are missing..."
I have chosen to "Skip All" each time because I have all the audio files and fade files that I need in the session. However, this message keeps appearing each time I load this session. How do I keep this from happening?
Thanks in advance for your help!
Old 06-28-2009, 06:57 PM
stonehenge stonehenge is offline
Default Re: How do I get rid of "Missing Files" message when PT loads?
i ran into that before but don't remember exactly how i fixed it. it was either using the task manager or maybe doing a save session copy in. sorry.
Old 06-28-2009, 09:06 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Go into the regions list view(the 1 on the right of the edit window) Look thru the files until u see ones that are sorta italicized for lack of a better description... click on all of them(if its ur 1st time doin it u may wanna write down the missing files to make sure u dont grab the wrong things) anywayz, get all those files highlighted, go up to the dropdown menu in the same window, go to select, choose clear unused regions, & then when the popup ask to remove or delete, hold alt+click on delete & that'll do it...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 06-29-2009, 02:12 PM
The strange thing is that there are no files that are shown in italics in the regions list, and all of the files in my regions list are being used. Any other ideas?
Old 06-29-2009, 07:27 PM
U may want to check again b/c there has to be if ur getting the missing files popup... ur in the Region window to the right on the mix window & not the 1 on the left correct?...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 06-30-2009, 09:03 AM
RichrdC RichrdC is offline
If you do end up deleting all unused regions as keybeeetssss has mentioned, (good idea... loosens up some memory) make sure you've unhidden any tracks that you may have Unactivated from the list on the left side of your session... Otherwise, you could end up deleting something you really didn't want to...
Old 06-30-2009, 01:39 PM
DigiTechSupt's Avatar
Also make sure that 'Show>Autocreated' is enabled in the drop-down list....
Avid Audio Tech Support
Support FAQ
Old 06-30-2009, 02:04 PM
001tony 001tony is offline
You might want to save to different location and then your deleting from a backup, just incase you delete some files you need.
Latest Project Here:
http://www.youtube.com/watch?v=G0OEwoLAbOg&feature
Old 06-30-2009, 02:32 PM
Great! I made sure that I selected "Autocreated" in the drop-down list, and I was able to find the 2 audio files that I needed to delete. Now I just have two fade files that I have to delete. How do I find those? There are no fade files in the "Fade Files" folder on my hard drive.
Thanks for the help!
Old 06-30-2009, 02:35 PM
Actually u can try & regenerate missing fade files when the initial popup comes up saying that they are missing... Just check the box that has that option & see if that helps... thatz just usually what I do when I have missing fade files...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Pro Tools sudden "missing iLok" message when connected external USB devices. mgoorevich macOS 5 01-04-2012 02:13 PM
Getting regular "missing Ilok" message after upgrading to V9 SD2 macOS 5 01-26-2011 12:46 PM
PT 8.1 audio "hits" or "pops" when i open files from PT7... djoeyd77 Pro Tools TDM Systems (Mac) 1 10-31-2009 03:59 AM
"Missing Files" - Another Feature Request Bignjhammer Post - Surround - Video 8 02-26-2009 01:17 PM
Structure - what does "Monolithic" mean as it pertains to "part" files? Jared_TL Virtual Instruments 2 12-07-2008 03:37 AM
