Old 11-04-2015, 06:24 AM
thierryhenry thierryhenry is offline
Default Color Palette Window- Great Shortcut
Not sure how late to the party I am but i've just discovered a great shortcut for bringing up the Color Palette window in ProTools which I can't believe i've missed:
Double click on the very top of the channel in the arrange window or the very left of the channel in the mix window.
Amazing! Hope this helps anyone else who this missed this trick.
Old 11-04-2015, 06:31 AM
Benny_Cha_Cha Benny_Cha_Cha is offline
Default Re: Color Palette Window- Great Shortcut
Nice one! Thanks!
Ben Rubin
Producer//Mixer//Bassist//Composer
benrubin.com
PT Ultimate 2024.3, Mac Studio M1 Max, 64Gb RAM, Mac OSX 13.6.4, SSD sample drive,
Neve 8816, HD Native Thunderbolt, (2) Lynx Aurora 16, Benchmark DAC-1/ADC-1
Old 11-04-2015, 06:33 AM
Drew Mazurek's Avatar
It's basically anywhere you see the color. Next to the name in the Edit window, and at the top and bottom of the Mix Window. Provided that you've got Track Color showing of course!!
www.drewmazurek.com
Old 11-04-2015, 02:03 PM
dieffe dieffe is offline
Or you just add a key command with the System preferences (on Mac) or with Quickeys (mac or pc) :)
I heavily use the color palette and I couldn't work without a shortcut to open the palette.
Cheers
Davide
Old 11-04-2015, 02:17 PM
Stig Eliassen's Avatar
Cool :)
I use window config for this. ", 1 *" brings up the color palette.
Old 11-04-2015, 02:28 PM
grayter1 grayter1 is offline
Davide
I've never done this. How do you go about it on a Mac?
Thanks,
tg
Mac Studio (2022) M1 MAX / 64GB / 2TB HD / macOS Ventura 13.6.5 / RME BabyFace Pro FS / SSL UF8 + UF1 + UC1 / Roland SYSTEM 8 / Kontrol S61 mk3 / Pro Tools Studio 2024.3 / Nuendo 13 / Reaper 7 / Komplete 14 / Omnisphere / Keyscape / Trilian / V Collection X
Old 11-05-2015, 12:31 AM
Thanks,
tg
Open System Preferences then
Keyboard
shortcut tab
App Shortcuts (on Mavericks, other version may have this menu somewhere else)
Add the Application with the Plus button, then write exactly the name of the menu (for the color palette, write Color Palette), and assign a key command (I use control+c)
You can add key commands to any function that has a menu name this way.
Hope it helps
Cheers
Color Palette gone... Possible bug? lapieuvre Pro Tools 9 0 07-15-2014 01:28 PM
PT 8 color palette problem bongo_x Pro Tools TDM Systems (Mac) 4 07-25-2010 10:36 AM
Color Palette question RichrdC Pro Tools M-Powered (Win) 6 04-23-2009 09:21 PM
LE v7.4-Color Palette & Track Color Coding Vbhalla Tips & Tricks 4 01-02-2008 04:13 PM
feature request Color palette frenchman Pro Tools TDM Systems (Mac) 1 07-04-2005 04:58 PM
