Old 10-29-2003, 10:01 PM
CHRS CHRS is offline
Default Help needed!!!
I'm using the MBox and was wondering how I could make a vocal track sound like it is coming out of a megaphone/speakerphone? Is there a filter or effect? Thanks.
Old 10-29-2003, 10:05 PM
Aze Aze is offline
Default Re: Help needed!!!
Wish I was at the studio right now, I'm at home on the gay little laptop. I've never done this with ProTools, but if you happen to have cool edit I could show you. I can also show you in Acid.
Get @ me.
And if you need it in a jam, you could send me the file and I could do it for you, then send it back -- then teach you how to do it after.
Old 10-29-2003, 11:53 PM
Roy Howell Roy Howell is offline
CHRS,
One option for this is the Digi 1-Band EQ plugin. I think you click on the Low freq button, and adjust its fader(in the plugin window) to as 'thin' as you want it.
~Roy
rh music
Old 10-30-2003, 12:52 AM
Phil O'Keefe Phil O'Keefe is offline
The way to approach this is to analyse the system you're trying to mimic. When you consider a megaphone or speakerphone, it's basically a limited bandwidth system - meaning that they don't reproduce high and low frequencies very well and instead concentrate on the area of the freqency range that human speech is.
So the way to go about this (on a prerecorded track) is to do some bandpass filtering - cut the lows and highs drastically and boost the mids. You can try a 4 band EQ with a lowpass filter set at around 6 KHz, a highpass filter set at around 500 Hz and a boosting bell filter at around 1 KHz. Adjust the different frequencies to taste.
Phil O'Keefe
PT 2023.6 Ultimate (Perpetual) | Avid Carbon | M1 Max Mac Studio; 32 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura.
PT 2023.6 Studio (Perpetual) | M1 MacBook Air; 16 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura.
Old 10-30-2003, 12:54 AM
Bastiaan Bastiaan is offline
It starts with how you record it. Let the person really yell into the microphone, and adjust the settings you are slightly overmodulating in the analog domain
Then have a go with the free Izotope vinyl plugin. It removes all the hifi from the track...
After that, compress the heck out of it
adding a little slap-delay without feedback will get you that "bouncing off the wall" sound
more info at http://izotope.com
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 10-30-2003, 08:59 AM
where02190 where02190 is offline
Go to your local toys r us and buy a megaphone.
Help needed batchmister1 Pro Tools M-Powered (Win) 1 01-30-2008 03:46 PM
OS 10.4.6 needed lcollen1 General Discussion 1 10-14-2006 10:10 AM
Help Needed meskalito 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-13-2006 08:49 AM
USD needed? peter kraemer ICON & C|24 2 01-05-2005 12:07 PM
Little help needed again..... Michael J 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 02-14-2002 12:21 AM
