Old 12-16-2023, 01:09 PM
seanmccoy seanmccoy is offline
Default Select Between Markers Not Happening
Hey, all. Since upgrading 2023.12 the select between markers from the Memory Locations window isn't working here as it always has. I can't find any new options or preferences that might explain it. Anybody else seeing this?
Custom i9-12900K, 64GB RAM, W10 Pro, PT Ultimate 2024.03, HD Native, OMNI, Digi 192, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.7
Old 12-16-2023, 08:07 PM
unkJE's Avatar
unkJE unkJE is offline
Default Re: Select Between Markers Not Happening
In Pro Tools 2023.12, to highlight the area between 2 Markers:
In the far-left column of the Memory Locations window, click alongside the 1st Marker of your selection.
Then SHIFT-click in the far-left column alongside the 2nd Marker of your selection.
Mods – perhaps merge this Thread with another (same issue) Thread:
https://duc.avid.com/showthread.php?t=426935
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 & Air 32 MINI * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock * 3 TB Samsung SSDs * 3 Screens: 15.6” Laptop & 24” BENQ LED GL2450-B & Samsung 27” CT550 curved Monitor
Old 12-16-2023, 09:49 PM
Excellent, thank you. I looked but could not find anything in the help files describing this new behavior. I knew it had to be something simple.
Old 02-26-2024, 08:58 AM
innerbooty innerbooty is offline
Thanks, I was just scratching my head over this issue as well, having just upgraded from 2021.6. Curious what the logic is between making you click in the far left column of the Memory Locations window instead of doing it the old way...?
2009 Mac Pro 5,1, PT 2021.3.1, HDX, Mojave, RX 560, Apogee AD/DA-16X, HD I/O 8x8
Old 02-26-2024, 09:41 AM
JingleDjango JingleDjango is offline
I'm not sure but I suspect there are still more changes to the markers system in the works. This may include modifying attributes of multiple selected markers at once.
Old 02-26-2024, 12:55 PM
Tweakhead Tweakhead is offline
This has got to be one of the most annoying, mindless changes in Pro Tools history.
The target area for mouse position to carry out this simple task is ridiculous.
Old 02-26-2024, 01:36 PM
BScout BScout is offline
The change was so you can make multiple marker selections and perform operations. Things like delete or move them to a different ruler. Hopefully more functions will come (like changing timebase.)
Pretty useful and a necessary change.
Old 02-26-2024, 02:05 PM
and 99% of Pro Tools users will never need to perform that task.
the remaining 1% will need to do it once a month, with 1% of the 1% doing it every day.
another rational decision from Avid serving their customers.
Old 02-26-2024, 04:26 PM
unkJE's Avatar
Useful video and article:
https://youtu.be/mZ4k1mspKSw
https://www.production-expert.com/pr...s-in-pro-tools
Old 02-26-2024, 07:10 PM
There's not a single thing they could change that wouldn't get some subset of the user-base up in arms about it.
2022.9 Win Can't select between markers? DFT Pro Tools 17 12-29-2022 02:41 PM
2021.6 Clips/Markers Grid Select Broken the.engineer Pro Tools 1 05-26-2022 02:26 PM
Beach ball in markers, select all, etc. improvpwnd Pro Tools 2020 22 08-31-2020 09:51 AM
Select area of audio in between markers mediapimp Pro Tools M-Powered (Mac) 2 10-20-2009 09:10 AM
Can't select audio between markers bwillman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-25-2008 08:38 PM
