Old 10-31-2021, 03:35 AM
Default Bug in 21.6 and 21.7
Found a major bug in 21.6 and 21.7
Create a splice into a continuous piece of QT. nudge the later half 2 frames later (to the right). Select across the gap and hit command-H. This should not heal but PT will heal anyway and kick the entire QT out of sync by two frames in your timeline. So after the heal your entire QT is now 2 frames out of sync.
This works for up to 2 frame gaps. Move the second half 3 frames or more and it won’t heal.
It doesn't happen with audio clips only QT. But it's quite dangerous.
Anyone able to test on 21.10?
Thanks!
Old 10-31-2021, 03:44 AM
Default Re: Major video bug in 21.6 and 21.7 and 21.10
Tried on 21.10 and it's exactly the same.
Old 10-31-2021, 07:08 AM
its2loud its2loud is offline
Default Re: Bug in 21.6 and 21.7
Bug, sure. Major? Probably not since Pro Tools is not a video editor. Does it happen in any version preceding 2021.6?
Write up a support ticket to let them know.
Old 10-31-2021, 07:19 AM
Happens in 21.3 and takes 5 seconds to reproduce.
Old 11-01-2021, 07:03 AM
quadraphonics quadraphonics is offline
Verified that it happens in 2020.12.
It pulls the first half of the video 2 frames to the right to heal the cut.
Randall
Randall Smith
Audio Editor/Mixer
Starz Entertainment Group
Denver, CO
Old 11-01-2021, 07:40 AM
Farhoof's Avatar
Farhoof Farhoof is offline
I can reproduce in 2019.6 as well. It's been here for a while it seems.
Old 11-06-2021, 07:13 AM
joachim's Avatar
joachim joachim is offline
Can reproduce this with 11.3.2 .
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
HTML code is On
