  #21
Old 07-13-2018, 07:49 PM
EddieJones's Avatar
Default Re: New Software Release EuControl Version 18.3
Originally Posted by cebolao View Post
@EddieJones
hi eddie
when can we expect the new version? the actual version has few annoying bugs - apart from what has already been written, i have found a new one:
when using layouts # 7 and above (which means pressing SHIFT to activate them) - the channel SEL key does not work. instead of selecting the channel it opens the eucon app window (which does not make any sence at all)
We are going to beta with the next version next week....not sure when the release will be yet though. I'll foward this issue to the test team and get it looked at.
  #22
Old 07-17-2018, 11:40 AM
EddieJones's Avatar
@EddieJones
Sounds like you are leaving shift on ?
  #23
Old 07-19-2018, 05:18 PM
cebolao cebolao is offline
indeed, when i unselect SHIFT it works
thanks for the tip, it makes it workable
however - why cannot i have SHIFT active? i might want to have it active, for example when i work on layers 7-12 and i need to select SHIFT+A, SHIFT+B etc all the time
  #24
Old 07-19-2018, 05:21 PM
a feature request:
if REC button is switched to changing automation mode there is a great feature that it blinks when writing automation. however, it works only for volume (fader) automation. if i start to write any other type of automation (with rotary encoders) it does not blink. and i think it should
  #25
Old 07-21-2018, 07:37 AM
EddieJones's Avatar
if shift is active then any other shifted operation will take effect
  #26
Old 07-21-2018, 07:38 AM
EddieJones's Avatar
Yes, we played with it both ways and most people thought it was weird/dangerous having the fader auto LED flash when anything was in record...definitely a pref needed
  #27
Old 10-09-2018, 05:42 AM
hello
when can we expect the new version of eucon?
the vca spill bug (spill skips the 1st track, starts spill from 2nd track) is really annoying, i struggle with it many times everyday...
  #28
Old 10-10-2018, 05:31 AM
EddieJones's Avatar
Soon...I'll PM you about a test version.
  #29
Old 10-30-2018, 09:04 AM
reichman's Avatar
reichman reichman is offline
Sorry, didn't see this until now. Me too!
Also have a bug where it's impossible to open an insert for a given track on either Dock or S3. Other tracks just fine...
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
New Software Release EuControl Version 3.7.0 EddieJones Avid S1, S3, Dock and Control App 6 02-09-2018 10:08 AM
New Software Release EuControl Version 3.7.0 EddieJones Artist Series 0 10-19-2017 12:09 PM
New Software Release EuControl Version 3.7.0 EddieJones Avid S1, S3, Dock and Control App 0 10-19-2017 12:08 PM
New Software Release EuControl Version 3.7.0 EddieJones Avid S1, S3, Dock and Control App 0 10-19-2017 12:07 PM
EuControl Software Package Version 2.6.2 for Mac OS X priorytools Artist Series 1 10-17-2012 08:41 PM
