Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 10-14-2015, 05:40 AM
MIKEIKE MIKEIKE is offline
Default Pro Tools First + Focusrite 6i6 Crash
I just setup Focusrite 6i6 with Pro Tools First PC. I changed my PC sound device to the 6i6 and when I opened Pro Tools, I selected 6i6 as the audio option. I could see signals, but received no sound? I then selected Asio4All and I received sound output, but it was very distorted as if it was cipping, but the signals were not? Then Pro tools crashed when I tried to select setup for Audio? After attempting to restart the computer a few times, everytime I selected Setup in Pro Tools it crashed? I had to uninstall and re-install software twice to try to get it to work. I'm using the default settings in Focusrite. I'm only testing by playing a percussion loop track. Any suggestions on settings: Asio4All? Scarlett Monitor Output 1 & 2? (Sample rate same). Using Windows 8 with Realtek High Definition Audio which I have disabled and instead selected The Focusrite 6i6. I plan to purchase Pro Tools 12, but if it is going to keep crashing, what's the point? Any suggestions on settings to assist stability? All of my system specs well exceed minimum requirements.
MikeIke
Old 10-29-2015, 01:20 PM
DigiTechSupt's Avatar
Default Re: Pro Tools First + Focusrite 6i6 Crash
Hello MIKEIKE,
Select Asio4All then go to Setup>Playback Engine and Select optimize for playback or toggle between the two settings.
Good luck,
RC
Avid Audio Tech Support
Support FAQ
Pro Tools 11 Crash Reporter - send in those crash logs! Bob Brown Pro Tools 11 37 01-29-2015 12:37 PM
Focusrite Scarlett 2i2/PT11 crash punisher911 Third Party Interfaces 1 01-06-2015 10:43 AM
Focusrite Scarlett 18i20 ProTools crash. BurtonTrucking Third Party Interfaces 7 04-17-2014 11:30 AM
Crash Crash Crash Live 6 Pro Tools Rewire TimmyP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-12-2007 11:26 AM
Installed 32track le version, won't run with Reaktor crash crash crash Christian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-02-2002 11:05 AM
