Focusrite with Pro Tools
I have the Focusrite Scarlett 6i6 and I'm using it with Cubase Pro 8 but I'm transitioning to Pro Tools. Is there anyone that uses Focusrite with Pro Tools? Maybe this interface specifically?
Re: Focusrite with Pro Tools
I have the Scarlett 2i4. Working flawlessly here! Do you have a specific question?
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
Have been using a Scarlett 2i2 for a few weeks with a MBP 2012 i5, OSX 10.10.4 Yosemite and Pro Tools 12.1 Native...
perfectly fine here ! No software needed, Class Compliant Mode means just plug and play and it does work. Nice feature this Direct Monitoring/true 0 latency function. Was able to record VIs at 64 samples without any problems. Fairly impressed by this little box! Great performance and amazing sound quality for this really low price . As mentioned above, flawless performance with PT12.1, OSX Yosemite on a 2012 MBP i5...here at least. |
Lots of problems/issues on PCs!
See http://duc.avid.com/showpost.php?p=2281007&postcount=30 for the latest/most relevant. Also, as I indicated on your PT vs Cubase thread (post #38) I used it (on PCs) too with the Beta and released drivers. My experience suggests that the released version is the lesser of the evils. It requires fewer workarounds and seems more "stable". As documented in the link in that post, other than it's distortion at 48 kHz sample rates (independent of DAW and driver), PT doesn't compensate for it's record latency (RTL) properly with that driver - if you even care about that (most apparently don't notice/care). Last edited by Amack; 08-31-2015 at 07:15 PM. Reason: Augment |
18i20 here, no issues. I usually use my Project Mix IO though, I use the 18i20 for mobile recording with extra inputs from my ProFire 2626 when needed (ADAT).
Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
It is a funny world. I'm considering the exact opposite transition.
Well, It is my impression that the Scarlett issues are more machine related (driver, USB3 etc.). Once you're "in", like you are with Cubase, and you have made it to the ASIO/CoreAudio layer, hopefully it should be downhill with Pro Tools as well. However, it is always a good idea to download the trial version and give it a test drive. Unfortunately, even the trial version demands the darn iLok (version 2).
Pro Tools 10.3.10, Cubase Artist 7.5.40, Allen & Heath Qu-16, Focusrite Scarlett 18i8 2G, Fujitsu Lifebook AH532, Intel Core i7-3612QM, 8 GB RAM, Windows 7 Professional SP1 64 bit |
Liquid Saffire pro 56
Saffire pro 40 Windows 7 64 bit ultimate, windows 10. Pro tools 10 11HD, 12HD No problem beside not being able to change the buffer size/sample rate from within pro tools, which happens to be the same like 99% 3rd party interface maker. |
I go mobile with the 18I8. It works a treat.
Unlike you, OP uses PCs.
The main thing to consider when using a PC is that WDM takes priority over the driver thus is the reason why you have to match sample rates in your windows sound preferences. You can also disable the interfere in Windows sound to avoid this extra step.
Pro Tools 10 CPU Overload w/ Focusrite S Pro 40 | Chenflakes | Pro Tools 10 | 1 | 05-03-2015 04:33 PM |
Focusrite RedNet with Pro Tools 10 non hd | jf.burman | Third Party Interfaces | 1 | 06-17-2014 03:53 PM |
Focusrite Saffire Pro 24 & Pro Tools 9 | AfterJohn | macOS | 17 | 03-31-2012 12:27 AM |
Pro Tools 8 LE and Focusrite Liquid Mix 16 | reycantong | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 08-31-2009 10:19 AM |
FOCUSRITE LIQUID MIX with PRO TOOLS | southboundloco | Pro Tools M-Powered (Win) | 22 | 06-12-2007 11:31 AM |
