Old 02-24-2014, 09:16 PM
Azulin Azulin is offline
Default PT11 Hui and Motu Traveler not working
From DP to Pro Tools... and boy am I feeling dumb!!
I cannot get the Mackie Control Universal Hui to show up/work on pro tools 11.
I have a MOtu traveler and an m-audio ozone....
Typically its just my laptop and the traveler, when I get home I have Mackie controller to mix...but I just can't get this this thing to show up, It also keeps telling me I am stuck in a loop... i am very new to pro tools and at this point Im clueless to what I am not doing correct.....
Any help or advice would be greatly appreciated.
Old 02-24-2014, 09:39 PM
soundboy35 soundboy35 is offline
Default Re: PT11 Hui and Motu Traveler not working
Connect unit via USB or MIDI (I have mine connected USB straight to the Mac)
Launch Pro Tools
Go to: Setup/Peripherals/MIDI Controllers
Type= HUI
Received from= USB/MIDI port in
Send to= USB/MIDI port out
Channels= 8
Click OK
That should do it.
What is this loop you mention?
MacBook Pro 15in, 2.3gHz,i7
PT 2021.x
PT12.8.x
Old 02-25-2014, 06:51 AM
My problem is in the send to and receive from options. On the first column i get the motu traveler as an option and on the second i get ozone 1 as an option.
The loop i get is the port 127 cannot... I forgot the exact language.
I thought i would getto set up peripherals, choose hui, choose traveler...
Thanks for your suggestions, im just not getting those options.
Old 02-25-2014, 08:31 PM
If you're connected via MIDI to the Traveler, you should have those options in the send and recv. You don't want the ozone. Try USB on the computer and see what comes up.
PT 2021.x
PT12.8.x
Old 02-27-2014, 07:59 AM
weezamiah weezamiah is offline
usb was the way to go for me. I tried midi,but even with mackie tech support they could not get the midi working. Usb straight to my mac mini.
Old 02-27-2014, 07:30 PM
Nice!
How big of sessions are you running on the Mac Mini? What model...i7?
PT10 or 11?
PT 2021.x
PT12.8.x
Old 02-27-2014, 08:18 PM
The only thing with a USB connection is the ozone. My Hui only has the Midi in and out, and the connection to expand and the two user stich auxs.
In the midi set up, I choose hui, then receive to traveler port, but there is no send option.
any other recommendations? stuck here....
Old 02-27-2014, 08:25 PM
In Midi, now i get hui, receive from traveler, send to new device...
and now I get a "Pro Tools unable to communicate with HUI please cycle through HUI and/or check connections..."
I am getting closer...
Old 02-28-2014, 07:40 PM
Hmmm, Control Universal and HUI are 2 different devices. Which do you have? If you have a HUI, you need to connect it via MIDI ports to your Traveler in and out and the Traveler to your computer via USB I assume? You might also need a driver for Pro Tools to see the Traveler's MIDI ports (not 100% on that)
PT 2021.x
PT12.8.x
Old 03-01-2014, 07:17 AM
Bill Denton Bill Denton is offline
Seems to be a little bit of confusion here...
We are talking about 3 different things:
  • Devices - Mackie Control Universal Pro (and it's predecessor) are "boxes" that you put on a desk (or wherever) and use to control software.
  • Control Surface Protocols - Within the context of this discussion there are two: MCU and HUI. HUI was written by Digidesign and Mackie jointly, has a somewhat limited feature set, but is the only third-party protocol supported by Pro Tools. MCU (or Mackie Control Universal...see the confusion?) was written by Mackie, has a larger feature set than HUI, and is supported by every DAW except Pro Tools (many of the other DAWs also support HUI).
  • MIDI Protocols (both communication and connection). The MIDI communication protocol is just a set of 1's and 0's that two (or more) devices use to communicate among themselves, and is not really germane to this discussion. As far as the MIDI connection protocols goes, I 'splained it several times already in this forum, so just do a search on here for my name and MIDI and messages within the last year to learn about USB and 5-pin DIN and coat hangers (seriously).
None of this stuff is complicated, but you do have to learn about it...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Locking up with MOTU traveler generator? Brent_Sydney Post - Surround - Video 0 02-28-2011 01:33 PM
Digi 003 and Motu Traveler undaunted Urge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-06-2011 08:03 AM
A switch from Motu Traveler to Mbox2 Pro mactools 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-04-2007 02:45 AM
MOTU Traveler Comments? Hollens Studios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-28-2005 02:44 PM
Motu Traveler & PT LE Terry Dycus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-08-2005 07:31 PM
