Plugin Preset Save - Can't locate settings folder
So I finally got through the iLok issue and am able to run PT 11. I'm just using the stock plugins at the moment and I noticed that none of them show a list of presets - they just list Factory Default. Further, when I make a change and try to save a preset, I get a dialog that indicates Pro Tools can't locate the settings folder.
Anyone else have the same issue? BTW, I am running a Mac, Mountain Lion 10.8.4. |
Re: Plugin Preset Save - Can't locate settings folder
All of them?
I just checked, and I am getting presets fine, and I can save. If you click "Save Setting As" that should show the containing folder. I'm on Windows 8 by the way, so it may be different on OSX. Attachment 380
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Yes, all the plugins exhibit the same behavior. It get the error message regardless of choosing "Save Settings" or "Save Settings As". If I choose the Presets drop down, then Settings Preferences, then Save Plugin Settings To, then choose Session Folder, it works fine. If instead of the Sessions Folder, I leave it at Root Folder, that's when I get the error message. It's almost like the install didn't complete a step or something. |
In Pro Tools 11 you can now determine the location of your basic settings, including plug-in settings.
Go to Pro Tools Preferences/Operation Then at the bottom left under "User Library" change the root. Or put your plug-in settings backup to the root location you'll see there. Oliver |
1) My user Library was pointing to a directory in my home directory - keep in mind the install configured this, it wasn't something I setup myself. 2) I had to change this to Library->Application Support->DigiDesign Once I did this, my presets came back and I was able to save settings, etc. |
"Unable to locate the settings folder" plugin error question | GoodandEvil | Pro Tools 11 | 1 | 12-30-2013 04:55 PM |
Import session data, plugin settings preset name | crizdee | Pro Tools TDM Systems (Mac) | 0 | 08-02-2011 07:37 AM |
Unable to save session copies w/ Root Settings Folder | nuancerec | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-03-2011 02:05 PM |
How to save preset settings on tl space or other plugins? | sonny7 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-11-2009 11:30 AM |
Cannot save plug-in settings to Root Settings folder | SimonORorke | Pro Tools M-Powered (Win) | 1 | 01-18-2008 08:38 PM |
