Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 04-21-2013, 09:23 PM
beatsamillion's Avatar
beatsamillion beatsamillion is offline
Default Mbox 3g Flashing lights sequence osx 10.7.5
ok im having the same problem as some people, now Ive been exchanging emails back and forth with avid reps and this is what i've concluded awaiting a response
because this was a new machine im using and its never worked on it they were quick to say its a hardware issue and had to send it in for repair
BUT
im using a macbook pro running OSx 10.7.5 and when i uninstalled all the drivers and just plugged the mbox in i get the sequence of lights again -ok
So i tried it on a i7 mackbook pro running OSX 10.8 with drivers installed then driver uninstalled and got the same thing sequence of light again SSSSOOOOOOO
I then got my hands on a old style MacBook (not Pro white hard case) running 10.6.8 what the mbox 3g was built for plugged it in and the sequence happened but after one cycle the solid power blue light came on ....soooo i installed the drivers and BAM it works great so we can rule out hardware issue
I tried the power hub.. that didn't work ether
and i just read somewhere it could be the OS ur running 32bit verses 64 bit? but there both running 64 bit
So its only safe to Assume Im having a compatibility issue?
but how do i resolve it ????
Old 04-24-2013, 11:43 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Mbox 3g Flashing lights sequence osx 10.7.5
BUT
Have you definitely got the latest Drivers released a few weeks ago? And made sure you've uninstalled all the old drivers...
http://avid.force.com/pkb/articles/d...ox-Pro-Drivers
Have you tried booting the mac into 32 bit mode? Hold down the 3 and 2 keys whilst booting.
And you're connected directly to the computer (no hubs)
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-25-2013, 05:13 AM
Thanks for the reply
Yes I actually tried the right ones and then downloaded them all.
Was on the phone with tech support for 1 and a half hours on Monday with no solution
This what I've done since
Installed 10.7 on a external hard drive and just the mbox driver - nothing
Wiped the main drive clean and installed 10.7 again -nothing
Now I'm going to try downgrading the os but I'm waiting for apple to send me a bootable cd copy should be in tomorrow
But no one mention the 32 bit option going to try that now
Old 04-25-2013, 05:52 AM
Originally Posted by crizdee View Post
Chris
Nothing bro sill the sameeeeeeeee issue im going to have to go see apple about this see if it actually my system
MBox 3 Lights flashing augster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 34 11-18-2018 06:52 PM
MBox 3 - Lights Blinking in Sequence doug6501 FireWire & USB Audio Interfaces (Win) 9 12-19-2014 08:08 PM
Mbox 3 Flashing lights drumzalicious FireWire & USB Audio Interfaces (Mac) 3 06-01-2014 02:23 AM
Flashing lights Mbox Sid0 FireWire & USB Audio Interfaces (Win) 11 04-23-2013 03:58 PM
Mbox 3 Flashing Lights. Sid0 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-17-2011 08:03 AM
