Old 09-09-2018, 06:57 AM
secutanudu secutanudu is offline
Default [SOLVED] Sample rate error
Hello,
Just yesterday I started receiving this error when opening any session or starting a new one:
Code:
Could not complete your request because Pro Tools could not set sample rate to specified value..
I am using PT 12.6.1 on Windows 10. Nothing has changed in my setup. It happens whether I am using my Lynx Aurora 16 LT-TB converter as my interface or I use ASIO4ALL with Windows audio. Both of these options worked until yesterday.
I verified that my Aurora is disabled in windows, so there shouldn't be anything in the OS trying to use it.
Any ideas on what this might be?
Thanks.
Old 09-09-2018, 10:07 AM
Wizzoboy's Avatar
Wizzoboy Wizzoboy is offline
Default Re: Sample rate error
Check to make sure that Windows has not changed your setup and is only using the PCs internal soundcard for itself. This error normally occurs when Windows is using your interface for itself and therefore wants to use its' own sample rate set in the Sounds, Playback, Advanced menus.
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - 3 screens - JBL Monitoring.
Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 546.01 - 2 x Internal Samsung 860 EVO SSDs, and MSATA card - Davinci Resolve Studio 18.6.4 - 3 screens - Blackmagic Speed Editor - MK1 Presonus Faderport - Canon C100 mk2 - Atomos Ninja 2 - Zoom H2n
Old 09-09-2018, 10:18 AM
Thanks. I've checked that. Windows is set to only use it's internal sound card. I've disabled all instances of the LT-TB, so Windows should not be able to use them. (see attached screenshots).
Also, I just tried using Reaper as a test, and I can use my Lynx I/O without issue.
This definitely seems to be a PT-only issue.
Old 09-09-2018, 10:23 AM
I also just completely disabled the "Windows Audio" service - and rebooted. My PC is currently running with no sounds whatsoever coming from the OS, and I still get the same error.
Old 09-09-2018, 05:10 PM
Any thoughts? I am pretty much dead in the water here. I tried using trasher, didn't help. Getting ready to try to reinstall PT.
Not sure what to try next.
Thanks.
Old 09-09-2018, 05:47 PM
BScout BScout is offline
remove your Lynx drivers, reboot, reinstall Lynx drivers, reboot, try it again
Old 09-09-2018, 06:03 PM
I just got it figured out. Somehow the Rate Lock option was turned on and preventing the Lynx from auto changing clock speeds.
Thanks for the replies.
pt 10 cant detect sample rate error?? help eatlife Windows 3 05-18-2012 07:31 AM
Sample rate error ! jeam25 Windows 2 10-30-2011 06:46 AM
Sample rate error during playback? Loudigi Pro Tools TDM Systems (Mac) 1 05-16-2008 05:06 PM
OMF error "unexpected error ...audio sample rate" StefB Pro Tools TDM Systems (Mac) 3 06-30-2004 02:24 AM
