64bit
hello, the only reason i am currently not updating from PT8 to PT9 is that i may switch from cubase 5 (or later) as soon as there is a full 64bit version, incl. adapted RTAS plug-ins. are there any news? thanks, marco
Re: 64bit
I heard it's gonna be released in March 2011 and I didnt update either so not to pay twice :S
Re: 64bit
Except for being able to use more RAM, 64 bits won't buy you much in a DAW. Yes, you will be able to use more VI but how many of you are running into problems with not enough RAM? I don't use many VI so 64 bits means little to me.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Re: 64bit
well, as soon as you are working with orchestral libraries, 64bit is a must just because of RAM indeed - looking forward to.
Re: 64bit
There are ways of getting around that if you want to work in ProTools.
Carl
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc. |
Re: 64bit
i have been using separate machines for years, but any way around it is not as elegant as having it inside, so to say - the same counts for sibelius, actually.
Re: 64bit
so protools 9 will have a 64-bit version come march? and they are gonna charge for it?
when cubase 5 was released you got 32 and 64 bit for the price. you didnt have to pay more foro the 64 bit version . . will we be able to run 32 bit plugins in it without bugs? (because i know cubase 5 is having HUGE issues with that....so much so that you have to go buy another piece of bridge software to even use 32 bit plugs in 64 bit
Win 7 64 bit AMD Phenom(tm) II X4 965 Processor Mainboard : Asus M4A78T-E BIOS : AMI 2402 01/05/2010 Chipset AMD RS780 Host Bridge Memory 6 gigs ddr3 1600mhz Memory OCZ OCZ3G1600LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) X 3 for 6 gigs Video Adapter : ATI Radeon HD 4870 X2 Western Digital Black 1TB, SATA300,7200 rpm 64MB Cache 932GB For PT WDC 500.1GB, SATA300,7200rpm, NCQ, 16MB Cache For Recording http://www.vampirefreaks.com/dawnofblack |
Re: 64bit
Routes each track directly into ProTools through an AUX track. Piece of cake. Carl
Re: 64bit
A single instance of Sample tank 2 can run over 500MB easily. 64 bit does not only increase the amount of memory available to the host computer, but also increases the amount of throughput in the CPU. With myself only having 3 GB of RAM, i plan to upgrade. I would like pro tools to be able to use a machine to its fullest extent. IMO, it should be here before 2012. Nick
Core i7 920 OC'ed @ 4.0 GHz (200 X 20) 12 GB Patriot Viper Extreme Asus P6T OCZ Agility 64 GB SSD Hitachi 1TB 32 MB HDD WD Caviar Black 500GB Saphhire HD 5850 3 x 20" monitors Eleven Rack w/ ERXP Fender Super Champ XD Marshall JCM2000 DSL100 Silver Edition W/ Silver Jubilee Cabinet |
Re: 64bit
As much as id like to believe it, i doubt it. There is no way they would script protools 9 in 32bit, and then re write to take advantage of 64bit. It wouldn't make sence. Nick
R E A L L Y - P I S S E D - O F - A B O U T - T H E - L A C K - O F - 64bit - PT 9 | Aerny | macOS | 25 | 06-06-2011 03:44 PM |
about PT9 on w7 64bit | ericyang1215 | Windows | 2 | 06-03-2011 02:45 AM |
E.T.A On P.T 9 64bit? | Steve_Brown | Pro Tools 9 | 107 | 01-06-2011 04:29 PM |
XP goes 64BIT | AfricanCaneKing | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 02-04-2005 10:24 AM |
64bit XP and PTs | Guit4Brains | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-22-2004 09:17 AM |
