PT 2020.11 won't open or create session
I tried to open older sessions and then create a new one, but I still have the same message that the playback engine does not support sample rate 32kHz. I'm using Antelope Eclipse 384 on 44.1kHz. It works great with Cubase. I really don't understand what's going on. I'm on MAc OS Catalina 10.15.7
iMac i9 3,6GHz, 80GB RAM, Mac OS 10.15.7, Pro Tools 2020.11, Antelope Eclipse 384 |
Re: PT 2020.11 won't open or create session
Sounds like you probably have the internal sound source selected instead of your interface.
__________________ Al Hospers bassist, vocal, composer, engineer https://www.youtube.com/channel/UCCw...ogfR_7Q/videos ------------------------------------------------------ PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones... |
I think i have selected Eclipse. View attachment. Also it always starts with the warning about TCE plugin.
I find it odd that the driver for the Eclipse is called Eclipse talkback. Might there be another device that shows up with a more appropriate name?
You need to change the clock on your interface to a supported rate. Pro Tools does not support 32K. Open AudioMidi setup and choose what the default coreaudio rate will be. If it's a rate supported by Pro Tools, it won't give you a problem. Sent from my iPad using Tapatalk
Thanks. It has Eclipse Talkback profile which is one channel output 16bit 32kHz. Then there's Eclipse 384 which is the interface. When I changed that in playback engine, everything went fine.
PT 2020.9 - Still can't open old PT5.1 Session files | cshaw | Pro Tools 2020 | 9 | 09-05-2020 06:39 PM |
Cannot open or create a session | EvMo | Pro Tools 12 | 2 | 07-18-2016 11:22 PM |
Pro Tools 9 won't open or create a new session | G-Lay | macOS | 9 | 05-09-2011 04:48 PM |
ProTools 8 crashes when i try to create or open any session | bendik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 01-14-2010 09:37 AM |
Can't open or create a session on new hard drive | Pierre B. Samson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-25-2005 07:24 AM |
