Old 11-25-2020, 03:41 PM
Austin4 Austin4 is offline
Default Audio and Video no syncing in PT12.4
Outside of PT, the video is just fine. After creating a new session with the same parameters of the video (fps/kHz) and importing media, audio is not in sync.
PT 12.4 / Mac OS Sierra 10.12.6 (Mid 2011) - Video is QT movie H.264 exported out of FCP (where it was just fine).
Suggestions?
FuturesPerfect Studios
http://futuresperfect.com
Old 11-26-2020, 09:24 AM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Default Re: Audio and Video no syncing in PT12.4
Convert the H264 to DNXHD36 with Shutter encoder.
H264 is a delivery file meant to be viewed only with married audio, not one to use in an editorial scenario.
IMDB
Old 11-28-2020, 05:23 PM
Led Led is offline
There used to be some wierdness on older versions with bit depth conversion ie - if the video audio is 16 bit, and the session is 24, the convert on the way in would put the audio a frame early.
HTML code is On
audio/video syncing problem after bouncing oplatner Windows 0 07-31-2012 10:33 AM
Syncing/saving audio and video together iguess macOS 2 02-01-2012 07:11 AM
Syncing Pro-Tools Audio with Video from Camcorder...any tips? Garjaye 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-17-2010 02:29 PM
Syncing Audio to Video/Delay Comp spearson8 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-06-2009 08:57 AM
Video & Audio Not Syncing in ProTools 8 LE!! Overmyhead35 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-24-2009 07:54 PM
