Eleven Rack Buzz
I recently bought an 11 Rack Bundle from Sweet Water, comes with (Pro Tools/11 Rack) and it was working amazing for the first 3 weeks. Then it started buzzing on every setting, regardless of it the 11 Rack was hooked up to Pro Tools or stand alone. I contacted sweet water and they replaced it with a new unit, only it start doing the same thing. I've tried different outlets through out my house, guitar cables, guitars with no help to solving the problem. Here are 2 links, one a recording of before this started happening and one with the buzz.
https://soundcloud.com/ceres-regnum/none-buzz-guitar-01 https://soundcloud.com/ceres-regnum/buzz-guitar-01 P.S I've always tried different settings within the 11 rack and an external noise gate. |
Re: Eleven Rack Buzz
Can't help because soundcloud says it can't find the sounds and that maybe I was trying to look at a private file.
Could you possibly try plugging the unit in somewhere else to rule out a bad power source?
I was in an apartment for a while that a couple of outlets had extra noise coming through. |
I figured out the problem, as crazy as it is it was the light in the next room over causing it. Which I can't believe because I tried everything, from different locations and outlets, turning off the lights in the room, but it came out to be lights in a completely different room. My biggest concern now is this an electrical issue in my house, or a problem with the 11 rack itself. I've owned many units before and have never had such a problem.
If you really need help contact a local ham radio (amateur radio) operator near you and he or she will probably be able to help you really get this sorted. I should know as I'm one and I've had to solve any number of strange issues like you have. That being said I'd like to hear what the sounds are like but as I said earlier I can't because soundcloud says it cant' find the files. |
Flouresent light? Was it on a wall dimmer? both of those can add noise. You might try a ferrite choke on the line cord. You can find them at Radio Shack. Its a big iron inducter you wrap the cord around. Some USB cables have them also. they are the ones with the cylinder on the built into the cable. Most of Avids interfaces have them.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
I'll re-post them as soon I get, as I had taken them down since the problem was solved.
Mac Book Pro 2012 - OS X Ver. 10.8.3 Eleven Rack Pro Tools 10 - Ver 10.3.2 Mac Book Pro 15" Monitor Specs - 2.6GHz Quad-core Intel Core i7, NVIDIA GeForce GT 650M with 1GB GDDR5 memory, Samsung SSD 250GB, 16.0GB PC3-12800 1600MHz DDR3L |
Yes it was a dimmer light, it controlled all the lights in my living room. The lights are those new eco friendly, super cheap 30 watt bulbs.
My guess is the Wall Dimmer.
GreenLite CFL Light Bulb 13w = 60w, also I probably shouldn't be using none dimmable lights on a dimmable switch >.>
Eleven Rack Output to Amp buzz | antonis | Eleven Rack | 45 | 10-31-2017 06:59 AM |
Eleven Rack window responds to changes on Eleven Rack, unable to record. | pine | Eleven Rack | 6 | 08-02-2012 07:50 PM |
Eleven Rack and Eleven Rack control window not matching | 11R Newbie | Eleven Rack | 3 | 04-18-2012 06:07 PM |
buzz on the eleven rack | padraic | Eleven Rack | 14 | 02-02-2012 02:44 AM |
The 002-Rack buzz, who's going laptop? | pk_hat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 06-05-2003 03:56 PM |
