Re: Adding another 888/24 to mix plus system
I know its been forever since i have posted but no the problem has not been fixed. I have a new HD system I work off of currently though. Yes they are clocked together. Definitely not a bad cable or interface because I have switched both out and they work ust fine seperate but not together. The second interface will not come out of stand alone mode upon start up. Any more ideas? |
Have you tried swapping the interfaces to see if it follows one of them? Does DigiTest reveal any problems?
I think SYNC is for HD and USD is for MIX. Connecting the (256x) superclock from interface A to B should be enough as far as clocking.
Yes I have stonehenge and the other interface works fine by its self. Like I said the problem seems to be on start up the interfaces stay in stand alone mode and will not come out...therefore pro tools will not start up. And yes it is clocked out of 1st into second interface. All hardware setting look like they should. I also run an HD 3 PCIe rig on a new mac pro so I am pretty familiar with Pro Tools and have been running this TDM system rock solid for 7 years off of 1 interface. To sum it up...the system runs and recognizes one interface fine and comes out of stand alone upon start up but once you make the hardware configuration for (2) interfaces, shutdown down computer, rehook 2 interfaces; (A) first then (B) second with Y Cable from Digidesign, boot up, the ANALOG 1-2 stays blinking (stand alone mode) on both interfaces all the way until the desktop appears. Then obviously you try to start protools and its says it can not see interfaces. Anymore ideas? Sequence of configuring? |
#16
Oh and DigiTest runs fine
#17
Are you turning on the interfaces first, before booting up the computer?
If you do an 'identify' in the hardware setup dialog (when the units first work), does it identify the proper interface? Could you possibly post a screenshot of your hardware setup window, so we can see if something there may clue us in to what's going wrong? |
#18
SYNC, USD or the like are only useful if you are syncing multiple systems... i.e 2 or more computers, a digital console, an ADAT deck, video equipment, etc. |
#19
After making the necessary changes in hardware setup in control panels... I shut down computer and hook the interface up like I described in the post before. Before I start the computer... 1) turn my scsi drive on 2)turn 1st interface (888/24) on and wait for it to fully come up 3)turn 2nd interface(888/24) on and it clocks no problem to first 888 4) turn computer on 5) Interfaces stay in stand alone all the way up until the desktop appears. 6) pro tools wont open. The cables for both interfaces are brand new from Digidesign and the Y cable is brand new as well. How do you take a screen shot? I have never had to do that. And yes when I click on both A and B in Hardware setup its give me my options for selecting interfaces and the 888/24 IO comes up as an option. Should I make the necessary changes in hardware set up first with out anything connected to the core card? Does that matter? I know this is not brain surgery so its kind of confusing that I am having this problem Best Regards, David Arnold |
#20
Shift-Apple-4 will take a screenshot of a boxed area you determine by clicking and dragging. |
OT: Adding UAD-2 RTAS to HD system. | lownotesinc | Pro Tools TDM Systems (Mac) | 1 | 10-19-2011 12:25 AM |
Adding a second LE system to Venue | MikeTrahearn | VENUE Live Sound Systems | 2 | 12-06-2008 10:31 AM |
Adding MIX cards to PT System | byronfunk | Pro Tools TDM Systems (Mac) | 1 | 05-29-2007 10:18 AM |
Adding ram to DIGI 001 system | jcress | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-04-2004 07:24 AM |
Adding a PCI Graphics Card to PT HD2 System | Stacey | Pro Tools TDM Systems (Mac) | 1 | 04-23-2003 02:05 AM |
