Old 05-01-2000, 01:51 AM
flavor32 flavor32 is offline
Default Re: Bouncing to disk to free dsp
Hiya noisemakers. I've used Amp FArm extensively and I use the same bounce technique for any tracks that I want to bounce with ANY given effect. The first thing I do is create a duplicate playlist for the track. Then I save any plug in settings TO THE SESSION folder (unless of course you want to use it universally for other tunes, then save it as a preset). When performing the bounce, I give the audio file an extension for its name like "vocal 1 bounce" and select "import into session after bounce." After the bounce, I SPOT drag the file onto the new duplicate playlist track and remove any plugins bounced. I can then recognize the bounced playlist as the one containing the "vocal 1 bounce" (ie.)or I can revert to the original unbounced track via the PREVIOUS PLAYLIST by restoring the original plugs and settings. I hope this makes sense and helps the flow!
[email protected] " TARGET=_blank>www.flavor32.com
[email protected] </A>
McKay Garner
Production/Stereo and Dolby Atmos Music Mixing/Composition
San Francisco Bay/Los Angeles/Web
http://www.mckaygarner.com
Old 05-01-2000, 06:41 AM
tld tld is offline
Thanks flavor32...I like that approach a lot. One good thing about it is that you can safely do a 'Select unused regions' and 'Clear selected' to clean up the session without accidentally loosing your original dry track, as it is still in use in a playlist.
Regarding the bounce to disk, one somewhat OT question comes to mind. When bouncing a mono track to disk, is it possibly better to just record the bounce onto a new track using a mono buss, rather than actually using bounce to disk? It seems to me that, when using bounce to disk, the mixer is splitting the mono track to the masters, and the bounce to a mono file is summing them together...seems like a lot of unnecessary mixer processing. On the other hand, with the track panned hard left or right, I suppose this may not be occuring anyway....any opinions???
Thanks in advance and thanks for all the above posts!
Tom
http://www.digitalaudiorock.com
The Protools Plugin Preset Co-op
Bouncing in session first vs. bouncing straight to disk... WATYF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-07-2007 03:17 PM
Bouncing to Disk s470prestige 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-31-2005 10:11 AM
Bouncing to disk djjstylz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-07-2005 08:15 PM
Bouncing to Disk tonedef 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-19-2005 01:37 PM
Bouncing to disk beggehorn Pro Tools TDM Systems (Win) 4 02-07-2000 10:02 AM
