Re: Track Folders Are Here .. !
I am pretty sure they are not going to try to sell us "Edit Window Cleanup Toolkit" but instead include the feature to standard and ultimate software -- not so sure about 1st though.
UAD: Codes a DAW from the ground up and gives it away to hardware customers for free
Avid: (After subscription fee) 2010 style track folders in 2020! |
To be fair, Avid's typically included PT with their hardware. Free is a complicated word in the world of sales. Much like "saving money." lol
Anyway it is a WELCOME addition and if they (UA) keep the ”add-on” efx priced low it might be a contender to PT for us who use several Apollo interfaces. As the UAD-2 plugins range from 149-ish and up to $300 I woumd kot expect to pay more than maybe max $99 for the added efx as none of them will work as a ”plugin” outside Luna. The normal UA plugins can be used in any DAW and thats why they are more money but these EFX ”plugs” wont work in PT or Live10 etc I expect them to be half price or less. They said that the Tape Emu and the 3 VI was included but everyone in the demos are very vague on the Neve of emulation if it is a paid addon or included.
I just hope folders reflect on the mix window too, separate settings from the edit window would be even better.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
#16
BTW Ill PM you tomorrow as it is 2.30 am here and i have to try to sleep for once but lets do the transfer this weekend Andrei. Be well!
#17
"Normal" Track Folders - A container where you can stick tracks. You can route anything anywhere, and stick it in this type of folder so that you don't have to look at the individual tracks. "Routing" Tracks (I think) (Logic calls the Summing Folder Tracks) - Similar to above, except that the Outputs of all of the Tracks contained within it are also routed to a common Aux, which is controlled by the fader for the "Folder Track". |
#18
So whatever it would be called ("routing folder") would be like automatic bussing? Like choose a dozen drum kit tracks, assign them to "routing folder" or whatever that is, and the folder acts as aux track and its output is common to all tracks in the folder.
Makes sense. Can the folder be assigned plugins too?
#19
That is correct. Routing folders essentially collapse the tracks under a common aux group that has the same functionality as a typical aux buss within PT - inserts etc. If you were to open a session wth routing tracks in an older version of PT, the tracks would be unfolded so to speak and an aux track would be created with those tracks routed to it to replicate the routing folder. Sent from my iPhone using Tapatalk |
#20
So to speak, sure. But technically it may be more like the new version creates the aux track and it is there as an aux track for backwards compatibility; and this folder track feature is manipulating that aux track and the individual tracks' outputs in a meaningful way.
Don't want to be nitpicking here but just pointing out that for backwards compatibility no older version is "creating" anything from a newer session. It is always the responsibility of a newer version to create structures recognized by older versions.
What are track folders, and what is the magic therein? | moshuajusic | Pro Tools 2019 | 10 | 12-14-2019 05:12 PM |
Feature Request - Track Folders or Trees | DrFord | Pro Tools TDM Systems (Mac) | 8 | 05-29-2010 07:45 PM |
track folders | vikingbrother | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-14-2005 07:45 PM |
red folders....... | Chris Lambrechts | General Discussion | 6 | 11-23-2000 01:43 AM |
Folders | fender | General Discussion | 0 | 01-05-1999 01:07 PM |
