Old 03-24-2003, 10:36 AM
robbins876 robbins876 is offline
Default MSI KT3 Ultra 2
After several problems with the Asus A7V266-C, mainly getting now display, I decided to switch to the MSI KT3 Ultra 2, and have had great success. Now my specs look like this:
MSI KT3 Ultra 2
AMD Athlon XP 2100+
768mb DDR
Maxtor 30gb HD
IBM 60gb HD
ATI Radeon 900 128mb DDR
SoundBlaster Live! X-Gamer
My question is, do you think this will be enough to run LE? Also, has anyone experience problems with this board and/or setup?
Thanks,
Rob
Old 03-24-2003, 10:51 AM
Allen Hallada Allen Hallada is offline
Default Re: MSI KT3 Ultra 2
Rob,
So far that motherboard has been very stable. You should be fine with that processor too.
Allen [img]images/icons/wink.gif[/img]
Old 03-24-2003, 10:52 AM
blizzard's Avatar
blizzard blizzard is offline
Hey Rob!
I had help putting my system together because of my lack of "know-how" regarding computers and how to set up a system so I can't get to specific but, I am using a very similar setup and after a few tweeks recommended on the DUC I have had no problems at all. ( knock on wood!! [img]images/icons/grin.gif[/img] ) I'm running PTLE and it's smmooooth.
Here's my info:
CPU: AXP2000+ / Volcano9
MB: KT3 Ultra ( VIA KT333 Chipset Based )
RAM: 2x256MB
System HD: 30GB Maxtor 7200RPM
Audio HD: 60GB Maxtor 7200RPM
Video: G4Ti4200
Sound: Sound Blaster Live 5.1(PCI)
Good Luck!
Andrew
DAW - ProArt B550-Creator / 5950X / 128GB / WD SN850 1TB / PT 2023.9 / RME UFX+
Macbook Pro Retina / 2.8GHZ / 512GB SSD / PT 2023.9
Old 03-24-2003, 11:19 AM
Lalaman Lalaman is offline
Rob,
I got the same mobo. You should be equiped more then sufficiently with the CPU and RAM you got.
Working with AMD XP1800 and currently stuck in 1024 MB RAM ( while more than 512 MB actually is of no benefit to PT ) problems occure only since PT being synced externally.
Internal though the system runs flawlessly.
Have fun!
Lalaman
Regular Ultra wide -Ultra 3-enclosures the same? elementsound Storage Subsystems 0 07-03-2004 01:43 AM
DUAL Ultra 320 w/Ultra Segate Drives Seller Pro Tools TDM Systems (Mac) 0 07-07-2002 02:43 PM
001 w/B&W G3 Ultra Wide espmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-13-2000 06:40 PM
001 w/B&W G3 Ultra Wide espmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-09-2000 05:21 PM
Ultra ATA-66 PCI card w/ 001 jethro 156 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-19-2000 11:03 PM
