Old 04-24-2018, 06:53 AM
Default RegEx-guru question
anyone know a RegEx code that can move X amount of characters from the head of a clip or track name to the end of a given name?
So to to turn this
HELLO_somemorestuffhere_123
into
somemorestuffhere_123_HELLO
for all selected tracks or clips?
That said all the characters after HELLO can have all sorts of different forms and length but HELLO_ is always the same. And I only want this to happen to the names that start with "HELLO_". Otherwise I could have simply used the find/replace and add suffix fields I guess...
Thanks
Frank.
Old 04-24-2018, 07:17 AM
Default Re: RegEx-guru question
Originally Posted by its2loud View Post
In Pro Tools?
Batch clip rename
Batch track rename.
http://www.avidblogs.com/rename-grou...-batch-rename/
Yes, but I'm looking for the RegEx code for the change I mentioned. Regular Expression code. Learning RegEx is beyond my brain's capabilities at the moment so I was hoping someone here might have a solution. It's probably the easiest thing ever for a RegEx-guru. :-D
Thanks
Frank
Old 04-24-2018, 07:49 AM
its2loud its2loud is offline
I’m no guru but this should get you there if you do a find all HELLO first for clips and tracks.
You can do it in Reg-ex but I’m not sure of the Command.
FIND should be ((\w+)_(\w+)_(\w+))
REPLACE should be. \3, \4, \5, \2, \1
You might need to play with TRIM or REPLACE to get what you want.
Make sure to checkbox Regular Expressions.
Old 04-24-2018, 07:58 AM
Awesome thanks, will try...
Actually your hint about find the "HELLO_" clips first already pointed me to the solution even without RegEx. How could I not see that...
What I did:
Find "HELLO_" by name
Select all in the clip list.
Then
Trim head by 6 characters
and add suffix "_HELLO"
Done.
Thanks so much!
Frank.
Old 04-24-2018, 08:11 AM
Great! That works too and it doesn’t give you a headache.
Old 04-24-2018, 08:24 AM
FWIW - you could do all of this pretty easily with Keyboard Maestro, including asking for the search field and then automatically finding, stripping, and pasting.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 04-24-2018, 08:48 AM
minister's Avatar
minister minister is offline
A Better Finder Rename lets you move phrases to anywhere else in the name. It's a great flow and very powerful.
ABetterFinderRename
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 04-24-2018, 09:27 AM
ABetterFinderRename
Yep I have that but this was specifically for renaming clips in the timeline to improve readability in tiny view.
Batch rename in PT can't rename file-names anyway.
Old 04-24-2018, 09:28 AM
Yes but PT has all that on board now in the batch rename window. Takes 1 second to process instead of key-sequencing over thousands of clips with KM.
Old 04-25-2018, 04:55 PM
minister's Avatar
Ah. I see, you want to rename clips (or track), not files. Sorry, my bad for not reading better. I need a Better Forum READ-er. :)
Tom Hambleton CAS
IMDb
-Starcrash
HTML code is On
Question for Allen or other guru (buffer issues) MFriendly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 11-14-2006 10:57 AM
A Sync I/O question for you bored audio Guru's Eric Heil Pro Tools TDM Systems (Mac) 4 02-17-2005 01:13 AM
A question for a wiring guru. IO Composer Post - Surround - Video 3 08-06-2004 04:30 PM
Question for midi guru old timers Donny MIDI 1 02-21-2004 06:52 PM
A Midi question for a Guru clarpark Pro Tools TDM Systems (Mac) 3 02-22-2003 04:10 PM
