Old 07-07-2012, 12:42 PM
madlo madlo is offline
Default Plugin raises gain 3db?
Having a strange problem wherein adding a plugin, in this case eq3 1-band, adds 3db (roughly) gain to the signal. I am using the eq as a high pass filter, so the level shouldn't be getting higher with the plug instantiated. Any ideas as to why this might be happening?
System=
macbook pro i7 2.66 dual
Pro Tools 10.2
digi 003/eleven rack (interface doesn't change behavior)
Mac OS 10.7.4
I have tried trashing prefs, restarting numerous times, word clock vs internal
Any insight would be greatly appreciated. issue does not seem isolated to eq3 plugin, e.g. channel strip gives same results.
thanks!
Old 07-08-2012, 03:05 AM
clausiii's Avatar
clausiii clausiii is offline
Default Re: Plugin raises gain 3db?
Everything´s ok! This is normal! Filters boost a bit at the point where you set the frequency. The more dB/oct you use, the more the filter boosts. Analog filters work also this way.
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Gain riding plugin Ted Blaisdell VENUE Live Sound Systems 6 01-21-2013 04:41 AM
Audio Suite - Gain Plugin…..???? YYR123 Pro Tools 9 2 04-08-2012 08:51 PM
Is it better to use a Trim plugin or Gain plugin? SpinningDisk Tips & Tricks 5 01-19-2010 02:43 PM
As Gain Plugin in PT 8.03 m4tune Pro Tools TDM Systems (Mac) 2 01-15-2010 09:07 AM
question about audiosuite gain plugin keithl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-06-2006 07:14 AM
