Old 02-22-2003, 10:56 AM
clarpark clarpark is offline
Default A Midi question for a Guru
I have a live (free tempo) track (drums,bass,etc). I then did some midi tracks. Now I want to identify beats but the midi notes are following the new grid. Is there a way to disable midi notes while identifing the beats so the midi doesn't get screwy?
I'm thinking I have to play the midi out to a sequencer and then play it back in after the grid changes, but if someone know better please help!!!
Old 02-22-2003, 03:21 PM
Default Re: A Midi question for a Guru
anyone?
Old 02-22-2003, 03:46 PM
Allan Speers Allan Speers is offline
That's a great question. It probably can't be done. I don't have a session open right now, but try this (it's a longshot) :
put the midi track into "regions" viewing mode. Then see if you can lock this region. MAYBE.
Your idea of using an external sequencer will only work if you DON't lack the sequencer to PT. If you do that you are likely to get a little drift, as no two computer crystals are exactly the same.
-Maybe it would work if you use midi beat-clock instead of mtc.
Old 02-22-2003, 04:10 PM
JGuth JGuth is offline
you can export the midi to midi file and then load it into another sequencer locked to PT.
I assume you saved a version before you identified any beats. It does have to be locked
w mtc or beat clock. There may be an offset due to passing thru another interface and computer (a slight delay) I've done this a lot.
If your beat map in PT is tight you can quantize the midi to it once it's recorded in. ( unless quantizing is against your principles...)
Question for Allen or other guru (buffer issues) MFriendly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 11-14-2006 10:57 AM
Anyone tried Guru yet? crizdee Pro Tools TDM Systems (Mac) 3 09-06-2005 10:05 AM
A question for a wiring guru. IO Composer Post - Surround - Video 3 08-06-2004 04:30 PM
Question for midi guru old timers Donny MIDI 1 02-21-2004 06:52 PM
001- Midi Guru Info needed jbird MIDI 8 04-21-2003 12:09 AM
