Old 08-06-2004, 01:19 PM
IO Composer IO Composer is offline
Default A question for a wiring guru.
Does anyone know how to mult a line-level signal without using a patchbay? Example, I've got a 1/4" TRS smpte signal that I want to split to all of my decks. Obviously, if I had a patchbay I would just mult the source signal, but I don't see buying a full patchbay just to split the signal 2 or 3 ways. I tried just soldering 2 cables together but I just get a weak signal. How would this be done inexpensively?
Thanks in advance,
Jamey
Jamey Scott
Dramatic Audio Post, Inc.
Burbank, CA
IMDB
Old 08-06-2004, 01:55 PM
Jack Dawson Jack Dawson is offline
Default Re: A question for a wiring guru.
If the equipment is capable, try "daisy chaining" the smpte signal, otherwise you'll probably need some type of distribution amplifier.
Good luck,
Jack
Old 08-06-2004, 03:07 PM
minister's Avatar
minister minister is online now
radio shack makes a very cheap distribution amp -- that's the best way to go. just remember to get the right adapters for it to connect to your TRS cables.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 08-06-2004, 04:30 PM
Sweet. Thanks!
-Jamey
Jamey Scott
Burbank, CA
IMDB
HTML code is On
Question for Allen or other guru (buffer issues) MFriendly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 11-14-2006 10:57 AM
wiring question 16yearsjeff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-22-2005 08:48 AM
Question for midi guru old timers Donny MIDI 1 02-21-2004 06:52 PM
A Midi question for a Guru clarpark Pro Tools TDM Systems (Mac) 3 02-22-2003 04:10 PM
Wiring Question On HD the dude Pro Tools TDM Systems (Mac) 1 02-01-2002 11:22 PM
