Old 10-30-2010, 08:20 AM
rhythmator rhythmator is offline
Default Pro Tools Crashes during "Restoring Tracks" portion of startup
iMac 7 4GB Memory
Digi 003
Eleven Rack
Mac OSX 10.5.8
Pro Tools 8.04
Dig 003 is the Master clock and ElevenRack is slaved to Digi 003 via SPDIF. Audio output to monitors originates at the Digi 003. ElevenRack is only used as an input device and passes its I/O to the Digi 003 via SPDIF cables
Problem: When loading a specific song, when Pro Tools gets to the "Restoring Tracks" startup message, Pro Tools crashes.
Other Songs load fine and I can create a song with no issues.
I suspect that there is some I/O issue between the ElevenRack and the Digi 003.
Is there some way I can delete the I/O setup and then rebuild the I/O paths after the song has loaded?
Old 10-31-2010, 06:35 AM
Ben Jenssen's Avatar
Default Re: Pro Tools Crashes during "Restoring Tracks" portion of startup
I don't think so. I think the I/O setup is set up as part of loading the session.
It might be that the session itself is corrupt. You could try to import the tracks to a new session, a few at a time. Maybe you can narrow it down to a track.
Old 10-31-2010, 06:50 AM
Chief Pronto Chief Pronto is offline
iMac 7 4GB Memory
Digi 003
Eleven Rack
Mac OSX 10.5.8
Pro Tools 8.04
This is happening to me a lot lately. I can work on a session, save, close, and when I try to re-open the session, Pro Tools crashes, freezes my whole computer and I have to hard reboot. I have to create a new session and import the session data for the corrupted session. But if I try to import all the tracks at once, it crashes again. If I import the tracks one at a time, which takes a LONG time, the entire session gets imported without issue. So then I can work on it for a while longer, but when I save and close and try to re-open again, it crashes. The cycle goes on like this.
Lenovo T61 T9300 Core 2 Duo 2.5ghz
4GB DDR2
2 1TB FreeAgent Xtreme External Drives
SIIG FireWire Express Card
Windows 7 Ultimate X64
Pro Tools 8.0.4 LE
Digi003 Rack || PreSonus D8 || ART MPA Gold || ART PRO VLA II || Ensoniq DP/2
M-Audio Axiom 49 || Behringer BCF2000
Yamaha HS50Ms
Bands: Captain Starr || stereoINs
Drums: 1 || 2 || 3
Guitars: 1 || 2 || 3
Old 10-31-2010, 06:54 AM
If I were you guys, I would be looking for an offending plugin.
First, why not try: pull out all non-digi plugins, try to open your un-openable sessions.
Old 10-31-2010, 07:00 AM
Doesn't make a difference - if it was a bad plugin, it wouldn't load at all when importing the session data. But, for me, it loads when importing session data, but not the entire session.
4GB DDR2
Pro Tools 8.0.4 LE
Yamaha HS50Ms
Drums: 1 || 2 || 3
Old 10-31-2010, 07:04 AM
This means it could be a plugin in my opinion.
Old 10-31-2010, 07:06 AM
ok I'll try the Shift-Open trick.
4GB DDR2
Pro Tools 8.0.4 LE
Yamaha HS50Ms
Drums: 1 || 2 || 3
Old 10-31-2010, 07:28 AM
definitely not a plugin.
4GB DDR2
Pro Tools 8.0.4 LE
Yamaha HS50Ms
Drums: 1 || 2 || 3
Old 02-09-2011, 11:35 AM
guitarman6 guitarman6 is offline
I'm consistently getting this issue with a session as well and it's driving me crazy. Things will be going smoothly, then pro tools freezes, I get the beach ball, session crashes, need to hard reboot.
Then after rebooting (twice - once hard reboot, then one regular) if I try to open session is crashed on the session is corrupt and I can never use that file again. Thank god for session file backups. I then use most recent backup and restore session from there and save as restored versions.
Any figure out what could be causing this unfortunate bug?
MBP M1 Max | 64 GB | 4TB | macOS Monterey Version 12.7.4
[Legacy] Mobile: MBP Retina 2.6 HGz Intel Core i7 w 16 GB 1600 MHz DDR3 running macOS Catalina (10.15.7) w/ Pro Tools Ultimate 2020.12
[Legacy System] Studio: Mac Pro 2 x 2.93 GHz Quad-Core Intel Xeon w 16 GB 1066 MHz DDR3 RAM running OS X 10.8.5 using Pro Tools v10.3.9 & v11.3.2 HDX w/ AVID HD I/O
Old 03-26-2011, 10:40 PM
685 685 is offline
fixed??
Pro Tools Crashes on Startup During "Setting Up I/O Paths" ChrisIQ Pro Tools 10 3 08-24-2013 05:27 PM
Popping sound during "Restoring Tracks" notr2d2 macOS 0 08-06-2013 10:24 AM
New PT 10 upgrade won't complete startup: hangs on "Restoring Windows" georgelegeriii Pro Tools TDM Systems (Mac) 0 11-19-2012 12:14 PM
Pro tools 9 crashes at startup "Bus error" in thread "MainThread", at address 0x0 danball macOS 2 09-26-2011 04:49 PM
Structure "restoring tracks activating insert" for ever houser Pro Tools TDM Systems (Mac) 0 05-20-2009 02:35 AM
