Old 06-25-2019, 05:31 PM
laki laki is offline
Default Bussing a Stereo Track to Mono Aux: Summing change from 2018.3 to 2019.5
Hi All,
I just recently upgraded from PTHD 2018.3 to PT Ultimate 2019.5. I'm on Mac 10.12.6 Trashcan.
I've noticed a change in how PT sums a stereo track that is bussed to a mono Aux.
In 2018.3 (and before) if you bussed a Stereo track to a mono Aux, it would yield a +3db signal (due to the summing).
In 2019.5, the same process yields a +6db signal.
I am seeing this across multiple suites on HDX and Native.
Old 06-25-2019, 06:04 PM
arche3's Avatar
arche3 arche3 is offline
Default Re: Bussing a Stereo Track to Mono Aux: Summing change from 2018.3 to 2019.5
Wow.really? Oh no. Messes up recalls then from pre 2019.5
Sent from my SM-G975U using Tapatalk
Old 06-25-2019, 07:16 PM
Could it be the pan law setting?
Old 06-25-2019, 08:07 PM
Possibly but the pan depth is set the same in both instances. So, they shouldn't be different.
Old 06-25-2019, 09:11 PM
SBP SBP is offline
Just saw your post and happened to be in in a studio with pt11.3.1. and also pt2018.12.0
So did the following check. Both have same result.
If I put 1k tone (Created via audio suite signal generator which would make it a coherent source) on a stereo track at -20dB and then route that to a mono aux the result is -14dB on the mono aux.
anyway hope the info helps
Cheers
Bruno
Old 06-25-2019, 10:06 PM
BScout BScout is offline
I think everyone needs to be clear if they are testing coherent or non-coherent/incoherent sources.
A coherent source will sum to +6. This has nothing to do with pan law but everything to do with audio physics.
An incoherent source should sum to +3.
Basic calculator and explanation
http://www.sengpielaudio.com/calculator-leveladding.htm
Old 06-26-2019, 12:06 AM
Hi Guys,
Thanks for this.
Here are two screen shots of the same session. I am using a file for the tone made by the Audiosuite Signal Generator @-20. It is the same file for the left and right.
2018.3 Mono= -17 Stereo= -20
2019.5 Mono= -14 Stereo= -20
Given Bruno's results, maybe 2018.3 is the problem?
Old 06-26-2019, 07:11 AM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Are the tones time aligned? Audiosuite tones are notorious for not starting the waveform exactly at the same point in time, so i would double check phase alignment
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 06-26-2019, 03:53 PM
This is why I used the same file for both left and right. Only way to be sure.
Regardless, I should get the same result in both versions of PT.
Old 06-26-2019, 10:42 PM
From Avid Support:
The issue you reported is by a known issue with PT12.0 - 2018.3,
which was fixed in PT2018.7.
The current version is working properly and the previous versions (12.0 - 2018.3) did not...
PT Summing Stereo Tracks to Mono - differences between PT10 and PT12 buyonnet Pro Tools 12 11 05-06-2017 01:17 AM
Change a track from mono to stereo in PT12 jamestr12 Pro Tools 12 11 04-14-2017 05:13 PM
Summing a stereo track to mono scadh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 06-03-2010 02:16 PM
SIMPLE Q' RE: Rec/bussing a stereo signal to mono. Rudiebassic Tips & Tricks 2 10-29-2005 06:01 PM
Bussing reverb - stereo or mono? MidnightFlyer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 06-16-2003 02:34 AM
