Old 03-30-2013, 10:12 PM
Rickaudio Rickaudio is offline
Default PT 10.3.4 is creating automation points.
Hi guys,
It is me or PT 10.3.4 is creating automation points each time I trim with my trim start, trim end key short cuts?
Old 03-31-2013, 05:50 AM
bortraws bortraws is offline
Default Re: PT 10.3.4 is creating automation points.
No it's not just you I was already searching for "trim to start creates automation breakpoints" on the DUC to see if someone posted about this.
10.3.4 does it here as well. And having the automation follows edit button on or off doesn't make a difference. After a trim to start PT places a breakpoint.
Very annoying. I was constantly having those moments that changes in my mix didn't make a difference because when I moved a fader it automatched back. At first I didn't notice it so I was constantly making wrong mix choices. It took me some minutes to realize what was happening.
Bortraws
Old 03-31-2013, 11:55 PM
mattpete's Avatar
mattpete mattpete is offline
That's a known bug that should be fixed in the next update.
For now, you can work around it by just using delete after selecting what you don't want. Or use B for break at an insert point and then select and delete the piece you don't want.
Matt Peterson
Avid Audio
Old 04-01-2013, 02:08 AM
Thanks Matt for chiming in.
Would that be Pro Tools 11 where it's fixed?
Bortraws
Old 04-01-2013, 02:33 PM
Thanks Matt.
I just go 10.3.3 until the next upgrade.
Yep I hope for the next upgrade to be PT 11.
and i hope it arrives before expire my WAVES Update Plan
Old 04-02-2013, 12:49 PM
WombatStudio.Org's Avatar
WombatStudio.Org WombatStudio.Org is offline
Yeah, this started noticeably happening for me in 10.3.2 and seemed to be fixed in 10.3.3 ...
Now it's back in 10.3.4 ... Hassle!
WombatStudio.Org • Digital Recording, Mixing and Mastering in Gibbsboro, NJ • USA
"It's not the gear ... it's the ear"
Old 04-03-2013, 08:27 AM
Snap Snap is offline
I started having this problem when I updated, but turning off the Automation Follows Edit button fixed the problem for me...
Old 04-03-2013, 01:31 PM
KMcK KMcK is offline
Can you post a step-by-step to reproduce? While some versions prior to 10.3.4 had this issue, I'm not seeing it on 10.3.4.
http://www.imdb.com/name/nm2384808/
Phantom Automation Points...arg! kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-25-2013 04:20 PM
moving automation points pinnacle macOS 3 08-05-2013 01:36 AM
creating loop points for the NN-XT??????? speaker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-20-2006 11:05 PM
creating loop points in a sample for the NN-XT speaker Pro Tools M-Powered (Mac) 0 10-18-2006 11:19 PM
Creating Cue points for Director 7.0 lrosier Tips & Tricks 1 06-25-2000 12:13 AM
