Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
  #41
Old 11-07-2019, 04:06 PM
JFreak's Avatar
JFreak JFreak is online now
Default Re: Pro Tools 2019.10 Discussion
Originally Posted by Sardi View Post
They do not listen.
Or, even more frightening idea, they do not know how. Avid has confirmed the rumor that they have been working on HDX voice upgrade for a year already witn no release (because certain percentage of cards would fail on firmware update) so maybe this sidechain compensation on native mixer is one of the neverending stories they are trying to do but so far have no solution..?
Janne
  #42
Old 11-07-2019, 08:11 PM
JingleDjango JingleDjango is offline
If that were the case, they must have really coded themselves into a corner with their audio engine. And i thought it got a significant overhaul in the last few years, when they moved to 64 bit? Every other DAW I've used had implemented the feature competently. When i began using Pro Tools a few years ago i was stunned to find that mix techniques I'd taken for granted in Logic and Ableton were totally impractical in PT.
Obviously i still see enough value in PT to continue using it (for now), but what gives? My guess is they're paralyzed by so much legacy code but will never have the resources needed to address the problem.
  #43
Old 11-08-2019, 10:40 AM
Nish Nish is offline
Just noticed the zip file of PT2019.10 changed to Pro Tools 2019_10_Win_RevA in our accounts, but don't see any mention anywhere or changelog either.
  #44
Old 11-08-2019, 10:54 AM
TOM@METRO's Avatar
I see this as well. And the file is a little larger. I'll ask.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2020.5 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
  #45
Old 11-09-2019, 02:34 AM
Installing on Win7 worked again but once I open a session the HUI is still screwed up so had to revert back to 2019.6 again. It looks like I won't have another choice than upgrade to Win 10.
  #46
Old 11-09-2019, 03:47 AM
ChuckS ChuckS is offline
It probably has the updated iLok installer.
PT 2020.5 DP 10.11 VEP 7.x MOTU M4 HP Envy 8G i7 Quad Laptop Win10 (x64 20H2)
PT 2020.5 DP 10.11 VEP 7.x 828mkII ADA8200 MTP-AV 2011 Mac Mini i7 Quad High Sierra.6
  #47
Old 11-09-2019, 09:57 AM
TOM@METRO's Avatar
^^^ Yes ^^^
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
  #48
Old 11-09-2019, 12:30 PM
gnprice gnprice is offline
Originally Posted by dmontron View Post
Installed 2019.10 (Mac) a couple of days ago from 2018.6 (which I’ve been using as Ultimate with minimal issues) and I had to revert back.
I was getting irregular delay compensation readings but worse I was not able to use video at all!
Every previous session I opened with video I’d get an error and the video engine would crash and endlessly restart until I canceled. When I tried to import a video I’d get an error that the codec was not supported and the video engine would crash and go into a restart loop.
I lost a days work (I know, I know... shouldn’t have even tried the update-but as I’m paying for it, liked the idea of some of the features and I lost better judgement) trying to figure it out before just reverting back; I don’t have time right now to start a case with Avid but I will.
After upgrading to 2019.10 (on top of 2019.6 running Sierra) I also encountered video engine crashes and endless restarts. The "codec was not supported" was also seen when trying to import a known-good h.264 mp4 file. Thanks to CCC, I quickly reverted back to 2019.6 and all is well. This is the first major issue I've run into along the way since updating from 11 -> 12 -> 2018 -> 2019. I'd be academically curious to know if a clean install would work? However, being a lazy degenerate, I think I'll just ride it out with what works. I will consider this exercise an example of: 1.) Newer isn't always better, and 2.) If it ain't broke then don't fix it.
  #49
Old 11-09-2019, 03:00 PM
john1192 john1192 is offline
yes .. sad state of affairs .. i love the coded themselves into a Corner Line ...
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD -OS 10.12.6 for PT 11.3.2 & 2019.6 last version
Logic Pro X latest version
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.14.6 - PT 2019.6 Ended here ..
RME BabyFace Pro
  #50
Old 11-09-2019, 03:32 PM
amagras amagras is offline
Now pay $200
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
S5 & Pro Tools 2019.5 MarcOFB System 5 6 05-13-2019 08:15 AM
Real time Pro Tools Discussion Cam B 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-10-2014 12:19 PM
Pro Tools LE to HD upgrade special: Open discussion Tony Cariddi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 920 11-24-2010 08:31 PM
Pro Tools LE to HD upgrade special: Open discussion Tony Cariddi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 194 01-11-2010 10:04 PM
