  #21
Old 07-14-2019, 04:57 PM
Default Re: Purchasing a NEW 27‑inch iMac with Retina 5K display.
Originally Posted by cmbourget View Post
That's what I was trying to say. The map provides 5k ...
What is this 'map'?
  #22
Old 07-14-2019, 05:19 PM
cmbourget's Avatar
cmbourget cmbourget is offline
Originally Posted by musicman691 View Post
What is this 'map'?
Oups, French translation by Google ! "Carte", in French, is also a geographical map. Google has translated "carte" as "map" instead of "card". I was talking about the graphics card ...
  • Pro Tools 2023.12 Studio, Nuendo 12, Samplitude Suite Pro X7, Wavelab 11, Dorico Pro 5, Melodyne studio 5.
  • Apollo X 16 and 7.1.4 studio (Focal Solo6 be, Sub, and Focal EVO)
  • Softube Console 1. UAD systems (USB3).
  • Mac Studio M2 Ultra 2023. 2T. 128 Go. + 2X 4 T NVMe ext.
  • AMD Ryzen 9 5950X 16-Core Processor 3.40 GHz 64 Go, full SSD
  • Roland V-Piano, Novation 88
  • Etc.
  • www.claudemarcbourget.com
  #23
Old 07-15-2019, 02:35 AM
walter rohrbach walter rohrbach is offline
I had the same thing with an i7 and I resold it. The sound of the fan (behind the screen) is unbearable. Everything is so tight in an iMac that it heats up and the fan is overused. At least with a hybrid disc.
On my MBPro (2018 / 2.6GHz / i7) I made good experience with "Turbo Boost Switcher Pro". Prevents CPU to overclock and keeps the fans low speed.
I didn't notice any advantage with PT sessions when the CPU switched to higher speed.
just my two cents
walter
walter-rohrbach.com
  #24
Old 07-17-2019, 03:08 PM
propower propower is offline
I am auditioning the same i9 1TB SSD 580X iMac (note the Stock 8G of RAM is a real limit for testing any video rendering). The CPU power is fabulous. The 580X is fine for audio and light video work. Noise is no issue as long as temps don't go up to 90degC where the fans start to ramp. An interesting thing to try is turning Turbo OFF (3.6GHz). I ran 40% load (logic meter) on a test session with mostly VIs. 70 degreesC on the CPU - no increase in fans (80 degC with Turbo Boost ON). Have lots more to do with this machine but it is much better behaved from a fan noise POV than the 2017 i7 iMac...
Of course all my testing is in Logic nowadays but that is a rock we need not turn over
DUC always a great resource though!
2017 27" iMac 3.8GHz i5, 1TB SSD
Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB
Musician: http://www.ivanlee.net/
Design Engineer: http://www.propowerinc.com/resume.html
  #25
Old 07-17-2019, 03:34 PM
cmbourget's Avatar
Originally Posted by propower View Post
I am auditioning the same i9 1TB SSD iMac (note the Stock 8G of RAM is a real limit for testing any video rendering). The CPU power is fabulous. The 580X is fine for audio and light video work. Noise is no issue as long as temps don't go up to 90degC where the fans start to ramp. An interesting thing to try is turning Turbo OFF (3.6GHz). I ran 40% load (logic meter) on a test session with mostly VIs. 70 degreesC on the CPU - no increase in fans (80 degC with Turbo Boost ON). Have lots more to do with this machine but it is much better behaved from a fan noise POV than the 2017 i7 iMac...
Thank you for the information. I must say, however, that the iMac i7 27 5k was running silently with Logic. It was with Pro Tools that the blower was exaggerated. Logic is not my DAW (I am now on Cubase 10), but it is obvious that it manages better the resources of the Mac. Another thing, because I am now in PC: no problem with Pro Tools or Cubase in 5k on the iMac. Perfect picture. On a PC, in win 10, it is still impossible in 4k ....
  • Etc.
  #26
Old 07-29-2019, 09:11 AM
Jared Paul Jared Paul is offline
Bumping this. Any further opinions re: the OP's question of Pro Vega 48 vs 580X?
For running PT especially with video.
I've found that with my 2014 MBP my graphics seems to often be my bottleneck (-9073 when I'm scrolling through my session, or when I open up a graphically demanding plug like Fabfilter Pro-Q3), so I don't want to skimp on GPU on my next machine. But also wouldn't mind saving $450 if the Vega 48 would be totally overkill.
  #27
Old 07-31-2019, 08:43 AM
Originally Posted by jamesleonard View Post
* Radeon Pro Vega 48 with 8GB of HBM2 memory OR, Radeon Pro 580X with 8GB of GDDR5 memory (What is the best graphics option for Pro Tools 2019?)
Any further opinions as to whether the Pro Vega 48 is worth the upgrade if getting the iMac i9 for Pro Tools?
Can Pro Tools 12 be used on Macbook 13 inch retina? yoamoeba macOS 7 05-04-2016 07:49 AM
Protools 10.3.9 Retina Display [email protected] Pro Tools 10 0 08-13-2014 11:38 AM
PT 11 Support for Retina Display...? ronwasserman Pro Tools HDX & HD Native Systems (Mac) 2 04-22-2013 05:43 PM
Using two 23 inch hd apple display's? Greene Pro Tools TDM Systems (Mac) 0 02-10-2006 09:03 PM
Running PT on 32-inch display SteveGarman Pro Tools TDM Systems (Mac) 2 12-06-2005 08:56 AM
