Old 01-18-2019, 03:52 AM
dg27's Avatar
dg27 dg27 is offline
Default Clean install of 12.8?
I'm running Win 7 Pro 64X and PT 12.4.
I've been seeing some very flaky behavior with PT 12.4 this week and think a reinstall might be advisable. But rather than reinstall 12.4, I think it's high time I install 12.8.3. I've been postponing that because I don't like doing it mid-project.
Need advice on the workflow for this.
I use Trasher 3: Should I back up Prefs, I/O settings, etc., uninstall 12.4, install 12.8, then restore what I backed up using Treasher?
I haven't done a reinstall in a while, and the last time I did was before I started using Trasher.
I seem to remember that there was at least one and possibly two folders related I believe to plug-ins that I dragged to another drive and then copied back over once I had reinstalled.
Any advice would be appreciated.
Thanks.
Old 01-18-2019, 06:31 AM
dg27's Avatar
Default Re: Clean install of 12.8?
I found this and hope it's still correct. It cites an older version of Trasher. I'm using Trasher 3, build 18.
What I'm most unclear on is what I should not backup then restore.
I definitely want to restore my prefs, plug-in settings, templates, and I/O settings.
I'm unsure about the databases.
https://www.pro-tools-pc.com/how-to-...ools-11-or-12/
Old 01-18-2019, 05:04 PM
dg27's Avatar
Looks like everything is resolved. Thanks to advice from musicman691 and guitardom I used Trasher 3 then uninstalled 12.4 and installed 12.8.3.
So far so good! All the issues including the missing bar 6 I reported in another thread are gone.
I didn't realize that Trasher 3, the link I posted above, and a video I found by googling were all courtesy of guitardom: Thanks.
This saved me a lot of hassle.
Old 01-19-2019, 05:28 AM
Good news indeed.
Now that the ghosts have been banished - make some good music
Jack
QAPLA!
Old 01-19-2019, 06:03 AM
dg27's Avatar
That's the plan!
I was concerned that I'd spend a few days sorting this out...it was really only the time it took to uninstall and reinstall.
Pro Tools 10.3.2 wont even install! After clean windows 7 install!!! shamanrock Windows 13 12-27-2012 04:39 PM
Clean install of PT 10 under fresh install of Lion bortraws macOS 0 10-24-2011 08:53 AM
Can't install Pro Tools 8! Clean install, new system, Vista! DJ Hellfire 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 31 01-09-2011 11:16 AM
Clean Install of OS X toneski Pro Tools TDM Systems (Mac) 8 05-07-2008 12:54 PM
Re-install or restore, and what is a "clean install"? dave23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-18-2001 06:41 PM
