Old 08-20-2013, 04:27 AM
bower.steven bower.steven is offline
Default Avid Virtual Instruments 10.3 Installer issue
I am new to pro tools. I forgot to download the virtual instruments installer when I first installed pro tools 10. I got the downloader from avid and installed. When I setup a new stereo instrument track, there is no plug-ins listed under the track. Can someone help me???
Old 08-20-2013, 06:13 AM
demodigi demodigi is offline
Default Re: Avid Virtual Instruments 10.3 Installer issue
On PT, Instrument instances are just a plug-in category (so they are listed with EQ, COMP, FX, etc). You need to insert your instrument in an insert slot (the first one is better so that your can insert more FX if needed later).
You also need to activate instrument view (menu "View/Mix Windows View" and select "Instruments"), then you'll see MIDI routing, MIDI mute, MIDI Volume, and so on.
Macbook Pro (Core2duo 2,4GHz RAM4GB SSD)
MacMini (Core i7 Quad@2,3GHz RAM16GB SSD)
PT 10.3.10 + PT12.4 / VEP5.3.1 / MacOSX.9.5 (MBP)
PT12.4 / VEP5.3.1 / MacOSX.11.1 (MBP)
PT 10.3.10 / PT11.3.2 / PT12.4 / VEP5.3.1 / MacOSX.8.5 (MM "Production" on SSD)
PT 12.4 / VEP5.3.1 / MacOSX.11.1 (MM "test" on HDD)
RME UFX (USB2 with MM and Firewire with MBP)
+ Vienna Ensemble Pro Server on PC Q6600/8Gb/Win7-Pro64-SP1
Old 08-20-2013, 09:31 AM
Bruce Paine Bruce Paine is offline
Admin Emeritus
You should be able to download the Avid Virtual Instruments installer from your Avid account:
http://account.avid.com
Look under Your Products after you login.
Bruce Paine
System Details
Where did the Virtual Instruments Mac installer boxman macOS 3 05-13-2013 10:06 PM
Avid Virtual Instruments 10.3 Installer (Mac) RokVox macOS 3 10-30-2012 04:40 PM
Avid Virtual Instruments 10 installer, no XPand sounds? digidesigner Virtual Instruments 1 10-12-2012 12:21 PM
Can't download Avid Virtual Instruments 10.3 Installer (Mac) [solved] quantise macOS 2 10-05-2012 03:37 AM
Avid Virtual Instruments 10.3 Installer Becharax Windows 3 09-18-2012 07:21 AM
