Old 01-31-2020, 06:24 AM
garnoil garnoil is offline
Default Can Pro Tools 2019.12 be installed in Sierra OSX 10.12.6
Can Pro Tools 2019.12 be installed in Sierra OSX 10.12.6? Sierra is not listed as qualified in the Avid website.
Old 01-31-2020, 06:50 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Can Pro Tools 2019.12 be installed in Sierra OSX 10.12.6
You can try but as you found out Sierra is not qualified any longer in case you have trouble you're on your own. I would *guess* not much has changed since 2019.10 which is supported, and Avid just dropped Sierra because they added Catalina to the list of supported OS which have been three latest for quite some time.
Janne
Old 01-31-2020, 11:39 AM
Southsidemusic's Avatar
Worked great! No issues at all on trashcans. Have used both Sierra and High Sierra without any problems. 2019.10 and 2019.12 same versions basically for what Sierra uses of the code.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 01-31-2020, 03:45 PM
TNM TNM is offline
when it will start making a difference is when Mojave (ie metal) becomes the minimum.. that will change things.. but then Mojave should work for years after that unless Avid decide to be extra difficult.. This is why I have settled on Mojave, as everything works including my virus.
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X.
Old 02-03-2020, 08:49 PM
b mcgibney b mcgibney is offline
Well I for one have rolled back from HS to Sierra just so I could keep using NI Reaktor 5 and Ozone 5. Would be nice if I could run 2019.12 on Sierra.
So it apparently works on trashcans but has anyone tried it on a 5,1 cheesesgrater?
Pro Tools Studio 2023.12, RME UFX, Mac studio and a bunch of nice noise makers
Old 02-03-2020, 09:19 PM
brianjanthony's Avatar
brianjanthony brianjanthony is offline
I have a 5,1 cheese doodle and run 2019.6. haven't tried .12 in the studio. but .6 works like a dog for me day in and day out. I can't imagine .12 being that much different
Brian
www.brianjanthony.com
MacPro 6 core 3.46 Cheese Grater
HDX and HD NATIVE
48 gig Ram
PT 2019. Something
Sierra
192 IO and 96 IO
TDM user way back. PT user since 98.
I'm either working, sick, or both.
Install pro tools 2019.10 over 2019.6? Clarkston Guy Pro Tools 2019 6 11-01-2019 08:12 AM
PT 2019.6 & OS sierra 10.12.6? In the real world? Trainwreckmusic macOS 8 10-28-2019 03:25 AM
High Sierra HDX 2019.5 not seeing Avid 192 Ray Lyon Pro Tools 2019 5 06-08-2019 01:11 PM
No MIDI thru in 2019.5 and High Sierra Ray Lyon MIDI 0 06-07-2019 08:19 PM
PT 2019.5 Installed - How Do I Remove PT 10.xx? sdelsolray Pro Tools 2019 1 05-27-2019 10:39 AM
