Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 01-05-2020, 12:19 PM
Cayce Cayce is offline
Default Kontakt Session String Midi Notes Stuck on Sustain
I’ve just paid over 600.00 for the Komplete 12 package, with a primary interest in the Session Strings. Right away I discovered that whatever note I stop the playhead on, the note sustains indefinitely, until I either find and play the note on my keyboard, or shut down the plugin. My research shows complaints in the Native Instruments support forum going back to 2012 on this issue, with NI telling people they're "working on a solution". This makes it impossible to work.
More research shows many threads in here saying it's Pro Tools that is the problem, so my first question is, whose problem is it, Pro Tools or Native instruments? The second questions would be, is there a solution or a workaround for it?
Thanks.
iMac (Retina 5K, 27-inch, Late 2015)
4 GHz Intel Core i7
32 GB 1867 MHz DDR3
2TB Internal Fusion Drive
2 4TB External Drives with Mirrored Backups
2 External Monitors: 27" & 65"
Old 01-05-2020, 12:29 PM
JFreak's Avatar
JFreak JFreak is online now
Default Re: Kontakt Session String Midi Notes Stuck on Sustain
It might also be PT problem. What is your MIDI Merge setting?
Janne
Old 01-05-2020, 02:21 PM
Benoni's Avatar
Benoni Benoni is offline
You can always click the 'PANIC' button to shut down all output from Kontakt. Good to know when you get those hanging notes.
Old 01-05-2020, 02:23 PM
I've not had the problem of late with Kontakt which is what the op is talking about. One thing that can cause sustained notes like the op mentions is not getting a sustain off MIDI message especially when playing a lot of notes at one time. Kontakt does have a 'panic button' - it's the exclamation point at the top right of the gui just to the right of the cpu & disk percentage indicators and just to the left of the NI logo.
Something else to check is the op using the Kontakt memory server and where are the samples coming from.
Jack
QAPLA!
Old 01-05-2020, 02:51 PM
Sardi Sardi is online now
Yeah, it still happens. Latest version of PT and KU.
I don’t know who the issue falls on as I don’t tend to write much outside of PT (whenever I get the chance to write that is), but it happens with basic one note stuff like basslines not just complex stuff.
I just personally chalk it up to more annoyances with MIDI in PT that I never see changing unfortunately.
Old 01-06-2020, 08:09 AM
Flyingrockstudios Flyingrockstudios is offline
Does this happen when you use the stand alone Kontakt outside of Pro Tools?
PT 2020.3 Ultimate HDX, Dual Slate Raven MTi2, HD IO 16x16, Mac Pro 6.1 2013, Focal Solo Be6, Roland V-Drums, DW drums
Old 01-06-2020, 09:01 AM
Southsidemusic's Avatar
Same here as Musicman. Haven’t seen this on 2019.10 and up on HS and Mojave here atleast. Although we never had that issue or we never ran into it before either.
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 01-06-2020, 09:52 AM
Wouldn’t know as I don’t really use Kontakt outside of PT. I could try it in Live or Reason if I get a chance but I have a strong suspicion it won’t happen there.
Old 01-15-2020, 02:37 PM
ZEUSS ZEUSS is offline
Definitely getting stuck notes. Session strings pro 2 and various other VI’s. I hit the mute button in Kontakt and it will stop. But still it comes back. Been like this for a few years. 2019.12 installed now. Maybe it’s a Kontakt issue? Maybe just another midi bug on the list.
10.14.6 Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2020.5
Macbook Pro, 2019 (15,1) 32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2020.5, Apollo 8 Silver
Old 01-15-2020, 02:58 PM
Have you hit the panic button in Kontakt? It's th exclamation point at the top right of the gui. That'll stop the notes from sounding. All the mute does is stop you from hearing the notes - it doesn't stop them.
Jack
QAPLA!
Stuck midi notes in Kontakt in PT 12.4 stops workflow jazubon Pro Tools 12 4 03-23-2016 04:54 AM
Moving MIDI notes and control data (sustain) simultaneously? tobbenos Tips & Tricks 14 09-24-2014 11:29 AM
More effective editing of Notes and Sustain on a Piano (MIDI) track Stig Eliassen Tips & Tricks 4 08-05-2013 07:35 AM
Pro tools 9 and Kontakt 4 - waaaaayyy too many stuck notes John_Toolbox macOS 4 05-05-2012 08:02 PM
MIDI notes don't sustain after being pasted jimthepisces MIDI 1 01-08-2008 06:28 PM
