Old 01-11-2006, 06:44 AM
tokyofan tokyofan is offline
Default outboard pre into Mbox; setting \"unity gain\"?
I just starting running a Grace 101 into the 1/4" input of my Mbox (bypassing the microphone preamp circuit) and am wondering if there's anything I need to calibrate on the Mbox. The guy at Sweetwater said to "set the Mbox to line" (OK) "and the gain knob at unity gain if possible. This way the audio signal is not being modified by the Mbox." OK, how exactly do I achieve "unity gain" and is it really necessary? A little confused on this.
Old 01-11-2006, 07:02 AM
Default Re: outboard pre into Mbox; setting \"unity gain\"?
Well, since the issues for gain staging are sound quality and headroom, you could just set it for wherever sounds best. I'd use the 'line' setting, with the gain all the way down.
Quad 2.5 G5, 4.5G RAM
Old 01-11-2006, 06:43 PM
Ditto. Likely the Grace is designed to output a +4 signal and the Mbox line in is designed to recieve a +4 with the gain all the way down.
Unity Gain on Mbox 2 mini? ferdipd FireWire & USB Audio Interfaces (Win) 1 02-24-2014 05:04 AM
Mbox Volume Knob 0dB Unity Gain zenstone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-01-2012 02:06 AM
unity gain on mbox Kelso 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-02-2011 01:07 AM
SETTING LEVELS...Unity Gain..? vjk Pro Tools M-Powered (Win) 1 08-03-2007 11:13 AM
using outboard pre w/mbox - gain knob setting? sgladm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 09-11-2005 09:35 AM
