Static in Audio/ProTools9 -win7 64
Hello anyone, I am desperately trying to get clear audio from Protools 9 under Windows 7 64.. I am not convinced its the fault of Avid, in fact I personally think its a Microsofts issue, but, after talking to them dozens of times, they don't agree with me. I have 3 sound cards on my PC all of which have varying amount of static. My DIGIRACK002 is by far the worse sounding thought. Every time I play multitrack recordings (that were recorded clearly under WIN XP) the WIN 7 play back has horrible static associated with the audio. I have removed/reinstalled dozens of times, even tried version 8.0.4 under win7, same thing! bad audio. Everything works perfect in XP. Personally, I can care less what protools version I run as long as it sounds like how it was recorded it (version 8 or 9).. But I need win 7 to work so I can get the great memory usage benefits. Anyone run into this? or have thoughts?
I am so out of ideas... Joe |
Re: Static in Audio/ProTools9 -win7 64
Dear Joe, we have the exactly same problem but after dozens of times asking and surching for answers, nobary have ideas about.
Did you already have fixed it? Could you help us? Thank you for help and Best Regards Nilson - Lemcasa produções |
Both of you(in separate posts) should post a Sandra report on your systems to get proper help and advice. Without details, its near impossible to help, but I can tell you that PT9 runs great on several Windows 7 64 bit setups(including 2 systems here). Its really down to a few things: compatible hardware, proper system settings and tweaks, and following the rules(like NOT trying to record to the C: drive). Hopefully, Joe.LoDuca can paste a Sandra report here(after all, its his thread) and someone can help solve the issues
Help us Help You - READ THIS Before Posting!
First off lem this is a big nono there should only b one interface / sound card in the system
Second click on the link that Albee gave u and run a Sandra report - if that is u really want to fix this issue
static in audio | DAPianist | Pro Tools 10 | 11 | 12-11-2013 08:20 AM |
MBox 3 Pro and Win7 Audio Devices | Zarabozo | Windows | 2 | 10-25-2012 07:36 PM |
Static noise with MP9 Win7 | johnsather | Pro Tools M-Powered (Win) | 11 | 05-08-2012 08:33 PM |
Venom on ProTools9 - no audio | r2go | macOS | 2 | 02-02-2011 10:44 PM |
PT 8.0.4 hangs importing audio Win7 64x | haquall | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-28-2010 08:44 AM |
