Hi; I just got 2019 and a new Win 10 machine. My Sandra will be in the first reply below.
My problem is when I am editing midi, the result is delayed. For example if I try to trim a note the tool does not immediately engage the note. Then there is a 5 second delay before the note is highlighted and the edit appears. Thanks!!~ Eb
Eric Bolvin Add horns to your project!! http://www.bolvinmusic.com/horns-r-us.html 408.236.2009 Last edited by ebjazz; 07-02-2019 at 09:33 AM. |
SiSoftware Sandra
ID Host Name : DESKTOP-HCSJJKO Workgroup : WORKGROUP Computer Model : Dell Inspiron 5680 Serial Number : 705**** Chassis : Dell Desktop Mainboard : Dell 0DYHRY Serial Number : .7057DW2.CNW************ BIOS : Dell 2.1.0 05/10/2019 TPM - Trusted Platform Module : INTC Intel 2.0 (PCR 24) Intel vPro : 11.8.65.3590 Total Memory : 16GB DIMM DDR4 Processors Processor : Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz (6C 12T 4.29GHz/4.6GHz, 4GHz IMC/4.3GHz, 6x 256kB L2, 12MB L3) Chipset Memory Controller : Dell Core (CofeeLake-S 6C) Host Bridge/DRAM Registers 100MHz, 2x 8GB DIMM DDR4 2.4GHz 128-bit Memory Module(s) Memory Module : Samsung M378A1K43CB2-CRC 8GB DDR4 PC4-19200U DDR4-2400 (17-17-17-40 4-57-19-6) Memory Module : Samsung M378A1K43CB2-CRC 8GB DDR4 PC4-19200U DDR4-2400 (17-17-17-40 4-57-19-6) Video System Monitor/Panel : ACI ASUS VS247 (1920x1080, 23.4") Monitor/Panel : Samsung SyncMaster (1920x1080, 24.0") Video Adapter : NVIDIA GeForce GTX 1060 3GB (9CU 1152SP SM6.3 1.5GHz/1.71GHz, 1.5MB L2, 3GB 8GHz 192-bit, PCIe 3.0 x16) Video Adapter : NVIDIA GeForce GTX 1060 3GB (9CU 1152SP SM6.3 1.5GHz/1.71GHz, 1.5MB L2, 3GB 7.6GHz/8GHz 192-bit, PCIe 3.0 x16) Graphics Processor CUDA : NVIDIA GeForce GTX 1060 3GB (1152SP 9C 1.5GHz/1.71GHz, 1.5MB L2, 3GB 7.6GHz/8GHz 192-bit) OpenCL : NVIDIA GeForce GTX 1060 3GB (1152SP 9C 1.5GHz/1.71GHz, 1.5MB L2, 3GB 7.6GHz/8GHz 192-bit) D3D 11 : NVIDIA GeForce GTX 1060 3GB (1152SP 9C 1.5GHz/1.71GHz, 1.5MB L2, 3GB 7.6GHz/8GHz 192-bit) OpenGL : GeForce GTX 1060 3GB/PCIe/SSE2 (3GB) OpenGL : GeForce GTX 1060 3GB/PCIe/SSE2 (3GB) Storage Devices Seagate ST2000DM001-1ER164 (2TB, SATA600, 3.5", 7200rpm) : 2TB (D:) (E:) (H:) WDC WD4005FZBX-00K5WB0 (4TB, SATA600, 3.5", 7200rpm) : 4TB (I:) (J:) (K:) Samsung SSD 860 EVO M.2 1TB (1TB, SATA600, M.2, SSD, OPAL) : 932GB (C:) Logical Storage Devices Masters (D:) : 488GB (NTFS, 4kB) @ Seagate ST2000DM001-1ER164 (2TB, SATA600, 3.5", 7200rpm) Samples (E:) : 977GB (NTFS, 4kB) @ Seagate ST2000DM001-1ER164 (2TB, SATA600, 3.5", 7200rpm) OthFiles (H:) : 398GB (NTFS, 4kB) @ Seagate ST2000DM001-1ER164 (2TB, SATA600, 3.5", 7200rpm) Music (J:) : 488GB (NTFS, 4kB) @ WDC WD4005FZBX-00K5WB0 (4TB, SATA600, 3.5", 7200rpm) Videos (K:) : 488GB (NTFS, 4kB) @ WDC WD4005FZBX-00K5WB0 (4TB, SATA600, 3.5", 7200rpm) Sessions (I:) : 1TB (NTFS, 4kB) @ WDC WD4005FZBX-00K5WB0 (4TB, SATA600, 3.5", 7200rpm) OS (C:) : 916GB (NTFS, 4kB) @ Samsung SSD 860 EVO M.2 1TB (1TB, SATA600, M.2, SSD, OPAL) WINRETOOLS : 478MB (NTFS, 4kB) @ Samsung SSD 860 EVO M.2 1TB (1TB, SATA600, M.2, SSD, OPAL) Image : 13GB (NTFS, 4kB) @ Samsung SSD 860 EVO M.2 1TB (1TB, SATA600, M.2, SSD, OPAL) DELLSUPPORT : 1GB (NTFS, 4kB) @ Samsung SSD 860 EVO M.2 1TB (1TB, SATA600, M.2, SSD, OPAL) ESP : 649MB (FAT32, 4kB) @ Samsung SSD 860 EVO M.2 1TB (1TB, SATA600, M.2, SSD, OPAL) Peripherals LPC Hub Controller #1 : Dell Z370 Chipset LPC/eSPI Controller Audio Device : Dell 200 Series PCH HD Audio Audio Codec : Realtek Semi High Definition Audio Audio Codec : 32768 0000 Audio Device : Dell GP106 High Definition Audio Controller Audio Codec : nVidia nForce MCP2S PCI System Management Serial Port(s) : 1 Disk Controller : Dell ICH8R (ICH8) SATA RAID Controller Disk Controller : Dell 200 Series PCH PMC USB Controller #1 : Dell 200 Series PCH USB 3.0 xHCI Controller SMBus/i2c Controller #1 : Intel ICH SMBus Printers and Faxes Printer : Send to Microsoft OneNote 16 Driver (1200x1200, Colour) Printer : Microsoft Software Printer Driver (300x300, Colour) Printer : Microsoft XPS Document Writer v4 (600x600, Colour) Printer : Microsoft Print To PDF (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : Canon iP2700 series (USB, Colour) Network Services Network Adapter : Bluetooth Device (Personal Area Network) (Ethernet) Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 1Gbps) Wireless Adapter : Qualcomm QCA9377 802.11ac Wireless Adapter Operating System Windows System : Microsoft Windows 10 Personal 10.0.18362 Platform Compliance : x64
Eric Bolvin Add horns to your project!! http://www.bolvinmusic.com/horns-r-us.html 408.236.2009 |
You're not letting the drives sleep are you?
Other than for possible housekeeping/backups why did you partition the Seagate and WD drives? There's no need to. |
Yes, I confirm. The same slow downs/delays/freezes when editing midi data, it is something with midi engine in pro tools, not about hardware, I have dual Xeon workstation, I work with midi a lot and never had such problems before 2019.6 appeared :)
I've had the same thing only in large sessions... it can get incredibly sluggish. But it showed up much before 2019.6 in my case
PC i79700K 4.8Ghz 32Gb ram Nvidia1050 Win 10 64 SSL MX4 |
![]() Quote:
Eb
So we should all put in tickets with Avid so they are aware of the problem.
Eb
So for those having trouble, I got on with Sweetwater support and it helps to make sure the midi editor is closed if you are doing the edits in the edit screen.
Eb
Hmmmm.... havent noticed this will keep an eye out for anything sluggish. I spent a few hours writing some drum tracks yesterday jumping from edit and midi edit windows without closing.
Rob MBP 15 2018 macOS Mojave 10.14.6 Touch Bar and ID 2.2GHz 6 core 8 gen Intel Core i7 processor (TBs to 4.1GHz) 32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard Pro Tools 2021.3.0 -23.# - HEAT applied, Cubase 9.5, Yamaha TF5, UR44, BEHA4700 ........and a bowl of M&M's |
27" iMac slow editing | madselhoff | Pro Tools 12 | 23 | 11-09-2016 05:00 AM |
Slow/Not Smooth Editing and Scrolling | sfx_555 | macOS | 3 | 02-08-2012 10:58 PM |
Editing: slow response. HELP! | Inthebox | Pro Tools TDM Systems (Mac) | 4 | 11-14-2011 11:31 AM |
slow playback after editing/consolidating | skwad | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-14-2006 03:47 PM |
Editing sluggish and slow with quicktime! Help? | Sunzate | Pro Tools TDM Systems (Mac) | 3 | 03-09-2005 08:04 PM |
