Old 03-09-2005, 03:04 PM
Sunzate Sunzate is offline
Default Editing sluggish and slow with quicktime! Help?
Howdy -
I'm running Pt 6.2.3 on and HD1 system. It's a dual 1.25 G4 with a bunch of ram.
Our session has a quicktime video of fairly high resolution going, and it seems to have radically slowed our editing capabilities... Nudging and moving regions is realllly slow and choppy. We're not sure if something in our computer has changed or if the video that was supplied to us is higher resolution than normal and has slowed everything down. If this is normal behaviour, then how do we make it run smoother? We don't want to set movie playback to high priority because then we can't watch the playback and make edits. Are there other things to try changing?
THanks
Adam
Adam White, composer.producer.engineer
www.studiocat.ca
Old 03-09-2005, 03:13 PM
soundeziner soundeziner is offline
Default Re: Editing sluggish and slow with quicktime! Help
I have had this happen too...Without knowing what hardware you are using to output video and what size and compression scheme is used on the video, I can only suggest the following.
Try reimporting the movie into PT.
Try switching the resolution of your video output card/interface to another setting and then back to what you need.
Todd A. Judge, MPSE
Old 03-09-2005, 03:24 PM
SessionKat SessionKat is offline
Try:
Thinning automation (or turning it off during editing)
Closing any open plug-in windows
Raise your cpu usage
hide "un-needed" tracks
Where is to video file located? If on firewire or scsi, I'd suggest moving it to an internal drive.
-tv
Tim vdB
Avid Audio
"There's a fine line between stupid and clever."
Old 03-09-2005, 08:04 PM
Chief Technician's Avatar
Is your video encoded as a DV stream? A movie encoded with Sorenson will slow the system to a crawl.
8.0.4 Sluggish Slow Transport - Not responsive?! it rhymes with truck Pro Tools TDM Systems (Mac) 25 03-26-2011 10:09 PM
Sluggish Quicktime video Tiki King Pro Tools TDM Systems (Mac) 9 01-15-2008 02:44 PM
Sluggish responsiveness with PTLE 7.3 - it's SLOW RandB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-18-2006 11:21 PM
Quicktime getting sluggish garret Post - Surround - Video 2 08-18-2006 02:55 AM
Very slow / sluggish performance... Woogness Pro Tools TDM Systems (Mac) 6 08-01-2004 05:32 AM
