Old 09-22-2020, 10:10 AM
BLG BLG is offline
Default Latency using external controller to control XPand!2
I'm using an Akai MPD218 to control XPand!2 and there seems to be just a few MS of delay between when I hit the pad and hear the sound. This is making it extremely difficult to record drum sounds accurately. I'm using a Focusrite 4i4 as my interface so output is routed there.
Is there anything I can do to minimize (or eliminate) this latency?
Old 09-22-2020, 12:20 PM
Ben Jenssen's Avatar
Default Re: Latency using external controller to control XPand!2
Reduse buffer size in playback engine. Options menu.
Old 09-22-2020, 12:25 PM
junkgear's Avatar
junkgear junkgear is online now
The latency is most likely coming from your interface Are you using the latest Focusrite software?
Like Ben said, if you are running a high buffer, try reducing it and see if it helps. For just MIDI, you can probably go pretty low.
Tell us a little more about your setup and we can try to get you going.
Will
System Details
Old 09-22-2020, 01:21 PM
BLG BLG is offline
I just bought the interface about 3 weeks ago and downloaded the software then so I assume it's the latest.
I'm trying to record Guitar, Bass, Drums (MIDI) and vocals.
Old 09-22-2020, 01:30 PM
BLG BLG is offline
If you're referring to PT there's nothing in the Options menu for buffer size. I did find buffer in Setup->Hardware. It was at 512 and I changed it to 128 or 64. We'll see if that helps.
Or were you referring to the Focusrite software? (Or the Akai software for that matter)?
Old 09-22-2020, 03:16 PM
That's what Ben meant. If the computer will handle the 64 setting, that should feel fine. Another way to hear latency is with certain plugins. Some can add zero latency, but others can add hundreds or even thousands of samples of latency. The way to know what's going on is to hit the VIEW menu and put a check next to Mix Window Shows>Delay Compensation. That will add a row of boxes across the bottom of the MIX window and it will show 3 numbers. The bottom number is the crucial one as it shows the TOTAL latency caused(and compensated for) by plugins. Watch those numbers and keep them near zero while recording. Once you get to doing a mix, you can pile on the plugins and not worry(unless you decide you need to add a part late in the game).
Can't get Xpand to work with iPad controller JeremyLotus macOS 0 12-09-2015 12:41 PM
How to control AIR Fuzz-Wah with external controller? lloydwatts60 Pro Tools 9 4 09-11-2011 09:25 AM
Xpand! controller (this might be a really stupid question) Michael P. Virtual Instruments 5 03-28-2008 10:50 AM
Can i save non defaut controller assignments for Xpand! The Dougfather MIDI 4 03-09-2008 06:52 PM
Use external Midi Controller to control aux send levels spacegnome Pro Tools M-Powered (Mac) 0 04-17-2007 12:46 PM
