Old 07-22-2012, 10:06 PM
2224 2224 is offline
Default re re wire
I am trying to rewire waves tune in pro tools 9 but can't find rewire anywhere in pro tools.
Can anyone help with this please??
JAMAICAN I IS
2008 2009 and 2010 Mac Pro 8 core with
64 GIG memory with 9 terabyte of hard drive space
blue ray player
HDX 1, 2 16X16 interfaces
sync I/O.
Old 07-23-2012, 06:46 AM
daeron80 daeron80 is offline
Default Re: re re wire
I never figured that out, either. I just use it as an Audiosuite plug-in, which works great. It would be nice to be able to audition the changes in context prior to printing them, but it's not the end of the world to undo, tweak, and try again.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 07-23-2012, 07:23 AM
dave911's Avatar
dave911 dave911 is offline
There is a rewire for the Waves Tune plugin that you have to insert in a Aux track to use the plug real-time.
Can't recall where it is maynbe listed as a multi-mono
It will still need to do a scan pass.
Old 07-23-2012, 09:05 AM
paulreed paulreed is offline
I have not used it in quite a while, but recall needing to plug the waves rewire plug in front of the tune plug to make it work.
Old 07-23-2012, 10:04 AM
Thanks for the pointers. What you do is:
  1. Find Waves ReWire in the Instrument list. :shrug:
  2. Instanciate it on an otherwise unused Aux track. :shrug:
  3. Place Waves Tune on the track you want to tune and open it.
  4. Do all your tuning work.
  5. Print the result to a new track.
  6. Copy that back to your original track.
If you want to hear it all through the plug-ins you had on the track you're tuning, you'll probably want to move them to the track you're going to record to and put it in record monitor. It's all very awkward. Apparently, PT is the only DAW that makes it so convoluted. Other DAWs make all that happen in the background for you. Maybe the next major version of PT will, too? If AVID survive long enough to give us one.
David J. Finnamore
Old 07-25-2012, 10:19 AM
YYR123's Avatar
YYR123 YYR123 is offline
So i have a question about re-wire .......not exactely about waves.
So i opened a session i made with i was using PT7 and i had re-wired Reason into PT ....Well i love the bass sound in Subtractor and I wanted to reuse it.....Do i have to install a rewire program then install Reason>>>>?????
Did i just make sense....??? What i mean to ask isRe-wire already in PT???? I used it on PT7 but haven't messed with it since....I know some other people use VEpro and other programs for that but doesn't Re-Wire come with PT/???? and if so where the heck it it...????
Thanks.
Daniel
Old 07-25-2012, 10:46 AM
Dism Dism is offline
Thanks.
I'm sorry, were you asking a question? I'm not sure you used enough question marks.
ReWire does indeed come with Pro Tools.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 07-25-2012, 12:39 PM
Best thing to do is open the old session in your current version of PT. Everything should load just as it did in 7.x. If it doesn't, something may not be installed right. To load a new instance of Reason, simply place the Reason instrument plug-in on a track, and Reason will launch and play back through that track using ReWire.
David J. Finnamore
Old 07-25-2012, 12:45 PM
Right. The first thing people tend to do is over-think it and look for ReWire itself.
When ReWire is working properly... you only need to look for the application you're trying to use. If Reason shows up as an Instrument in Pro Tools, then ReWire is working.
D
Old 07-25-2012, 01:21 PM
TOM@METRO's Avatar
Or at least present.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
[IMG] code is Off
How to wire this!? im new at this steveguitargt Pro Tools M-Powered (Win) 3 07-20-2007 05:26 AM
re-wire Krav 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-03-2007 08:21 AM
How do you wire TRS -> XLR??? Camilo Orozco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-17-2004 02:30 PM
Wire this... spicyitaliano Pro Tools TDM Systems (Mac) 4 01-27-2003 10:55 AM
How to wire up an LA-3A? pnoise Pro Tools TDM Systems (Mac) 2 04-16-2002 12:07 AM
