Old 11-25-2020, 04:15 PM
Mishabou Mishabou is offline
Default Re: Quality control of LtRt
Originally Posted by smurfyou View Post
Ah thanks for clarifying. I would be strongly tempted to use the Dolby hardware. The last one I used was DP564 I think. Does PL-II decode and takes AES/EBU input. I think the 562 and SDU4 only do PL-I with a mono surround, which maybe is OK for your use? Either way they're reliable and don't break with Mac OS changes...
I used the Minnetonka for years, both RTAS and VST. Worked great but would definitely need a test run to see if it works with Catalina.
I believe LtRt found on film optical track are only PL-1, for 5.1, it uses Dolby Digital (also known as AC3), and are printed between perforations. Pretty sure the PL-2 was strictly a consumer format.
I will most likely use a SDU4 strap on the output of my Resolve rig. Thanks.
Old 11-25-2020, 05:33 PM
smurfyou smurfyou is offline
Good point.
~Will
Old 12-29-2020, 02:38 PM
emilano emilano is offline
Is anyone here still delivering LtRt mixes? The topic comes up here every once in a while. I haven't touched an encoder in years.
I still make LtRt's just because it makes so easy to mix. I monitor and mix in 5.1 but the encoder automatically creates a balanced stereo version of it for you.
Old 01-02-2021, 04:21 AM
tom_lowe tom_lowe is offline
Yeah it was called Dolby Surround. Are you sure all the films being scanned are LtRt mixes? I work with a lot of archive material from the 50s through to the 90s, and it's mostly mono with a bit of stereo in the 90s, albeit this was animation either shown in cinemas (the earlier stuff) or at festivals or on TV.
HTML code is On
HD Omni volume control quality robertszydlo Pro Tools HDX & HD Native Systems (Mac) 5 02-04-2015 04:58 PM
Quality Control question regarding tier 2 garnoil Post - Surround - Video 4 10-31-2013 09:05 AM
Quality of MicPres in Digi 002 control surface favanuestudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-24-2003 08:46 AM
Paint Quality on Control/24 J Fernandez ICON & C|24 6 01-24-2002 11:02 PM
Digi001 quality control problems.... Burton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-14-2001 01:15 PM
