Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
  #21
Old 05-16-2016, 07:19 AM
JoelG's Avatar
JoelG JoelG is offline
Default Re: Mbox 3 pro on Windows 10
The Mbox 3 line are still supposed to be getting updates, http://avid.force.com/pkb/articles/e...EUCON-and-ISIS lists devices that will not be supported beyond Win 8. That said, I don't have any info on when/if drivers will be updated to fix particular problems.
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
  #22
Old 05-16-2016, 09:38 AM
mcasey329 mcasey329 is offline
There may not be new information on when a new driver to fix this particular problem is. However
Does Avid recognize this is a problem and not an isolated incident?
DO they have any kind of response, workaround or fixes we can try to solve the problem?
Is there any information on what may be causing the issues so we can explore potential fixes and workarounds on our own?
Dell T7610 fully loaded.
Dell M4700 Fully loaded.
Pro Tools 12.5
MBOX Pro 3
Sibelius 8.3
  #23
Old 05-16-2016, 12:16 PM
JoelG's Avatar
A few suggestions - try another USB cable. If you're connecting to a USB 3 port, ether try a USB 2 port if your computer has them, or use a USB 2 hub between the computer and Mbox. Be sure to go through the Optimization guide (there isn't one for Win10 yet, so use the Win8 one), especially the parts about power saving features.
Joel
Jam Space:
Home:
Rig:
  #24
Old 05-18-2016, 08:59 AM
risey's Avatar
risey risey is offline
This might help some of you, it did not for me but something interesting happened. I installed ASIO4ALL in my last attempt to get MBOX 3 PRO to work and get recognised in ProTools 12 on Windows 10, it worked, it recognised mbox and loaded the session, however.... thats it... never got further, wont play, the only output offered was a SPIDF. Point is it may work for you, search ASIO4ALL...
http://www.PhatMonkey.me
Windows 10 64bit | Asus Rog Hero Xi | Intel i9-9900K | Corsair LPX Vengeance 64g DDR4 RAM | Avid Mbox Pro 3 | Focusrite 18i20 2nd Gen | MSI RTX 2080TI Gaming X Trio | Acer Z35 Predator Monitor
  #25
Old 05-18-2016, 12:21 PM
I ran through the optimizations for Windows 10 as found here.
http://avid.force.com/pkb/articles/t...ndows-10-Guide
My MBox is a firewire not USB. I although can try changing ports on the firewire card since it has two. It is the LSI card recommended by Avid.
Pro Tools 12.5
MBOX Pro 3
Sibelius 8.3
  #26
Old 05-26-2016, 05:53 PM
Since I lasted visited here I have tied the following with failures.
  1. Bought a new and different firecard card
  2. Tried the firecard card with power supplied by the computer.
  3. Used multiple different firewire cables
  4. Used all the various port combinations on the MBox and the firewire cards.
  5. Updated all my drivers on the system.
Bottomline for me is that the Mbox is not truly compatible with Windows 8 or above and seems worse on a Windows 10 system.
Until Avid produces a new driver we're SOL.
Time for a newer better supported AI for me since Avid has no time frame for a new driver and seems unwilling to share any info.
Pro Tools 12.5
MBOX Pro 3
Sibelius 8.3
  #27
Old 05-26-2016, 06:11 PM
risey's Avatar
Hi there, one thing to take into account, is your firewire card by Texas Instrument? This seems to be one of the more popular cards with a chipset that works well for audio configs. My texas worked fine on Win 8.1, I also had a Startech one which did not work for the Mbox 3 pro. There is a program called OhCitool which can check your firwire card compatibility with motherboard, google it.
Good luck, I am moving on to 8pre, Win 10 drivers out soon...
Ryan
  #28
Old 05-26-2016, 06:41 PM
I have on startech and one TI chipset. That is why I tried the second one. I will download the program you mentioned just to be sure.
I ran the OhCitool and both received no capability issues.
Thank you.
Pro Tools 12.5
MBOX Pro 3
Sibelius 8.3
  #29
Old 05-26-2016, 11:52 PM
I just noticed that the driver page now claims windows 10 support for the MBox pro 3,
http://avid.force.com/pkb/articles/d...ox-Pro-Drivers
Since this is now supported and my equipment and firewire cards are all in order how does someone go about getting a real person to help get it working correctly.
I have put in my due diligence with my time and efforts to get this to work and could use some real technical help from avid.
Marty
Pro Tools 12.5
MBOX Pro 3
Sibelius 8.3
  #30
Old 05-27-2016, 04:24 AM
risey's Avatar
Marty
OMG this is hilarious, they must have added the Windows 10 support text recently because it was not there before and notice the driver is still 2014. There is something very misleading and fishy going on, I would personally advise anyone that has clean installed Windows 10 to stay away from MBOX 3 PRO...
Updating Pro Tools and Mbox from Windows XP to Windows 7 ryanjantz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-29-2011 04:22 PM
Original MBox with Windows Vista or Windows 7 JoshuaD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-16-2009 06:57 AM
Original MBox on Windows Vista or Windows 7 JoshuaD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-16-2009 06:50 AM
Mbox on windows XP soebx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-27-2003 08:50 AM
Mbox and Windows ? Eliza 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-15-2002 06:53 AM
