Go Back   Avid Pro Audio Community > Legacy Products > RTAS & TDM Plug-ins
Old 08-13-2014, 01:03 PM
Raoul23 Raoul23 is offline
Default SSD4 issue with midi
Hope someone hear might be able to shed some light on this. I've got a roland TD11 kit I come from the midi out using the M-Audio UNO to the USB port on my PC. Now my issue is strange when I play the Roland just as a stand alone kit the hi hat triggers normally but when I play the roland as a VI via pro tools Steven Slate drums it seems like something can't keep up when to play 16th's on the Hi Hat it seems to miss a few. Anyone experienced this or know how to solve this. Is it the midi UNO do you think. I've watched fast drummers on the net using SSD4 and a roland kit and theirs always sounds good. This has stumped me
Thanks in advance
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 08-13-2014, 01:37 PM
hjorte's Avatar
hjorte hjorte is offline
Default Re: SSD4 issue with midi
SSD4 version?
Old 08-13-2014, 01:47 PM
Originally Posted by hjorte View Post
SSD4 version?
I know there was a release when the hi hat was an issue but its not that version. The version I have installed is RTAS 1.1.
Raoul Crane
Old 08-13-2014, 01:54 PM
hjorte's Avatar
Dang it, then I don't know. There is no TD11 IOmap conversion included with SSD4 but I doubt that's the problem. There is a SSD4_to_Roland_TD20.iom though.
Old 08-13-2014, 02:03 PM
I tried the TD20 iom and I find the SSD iom works the best for my kit. I must admit I don't understand why some of the expansion pack comes with its own iom. Coz if I normally used say the SSD4 iom and load the CLA expansion kit I then take it I should load the CLA iom but then that defeats the point of having the SSD4 iom loaded ???
Raoul Crane
Old 08-13-2014, 02:35 PM
hjorte's Avatar
I'm a bit confused too, so I'd rather not try to explain. If you haven't already, you should read the SSD 4.0 thread over at Gearslutz. I haven't read it all yet, but it has something about these iom files.
http://www.gearslutz.com/board/music...-4-0-a-21.html
Old 08-13-2014, 02:51 PM
Ok ill give that a read :)
Raoul Crane
SSD4 for $99 YYR123 The Drum Room 3 08-06-2014 09:12 AM
Problem with SSD4 Drums and Grid nhmorgan79 Pro Tools 10 2 02-26-2013 05:18 AM
Inconsistent midi trigger latency:PTX, SSD4 and UA epiphone macOS 0 09-04-2012 12:38 PM
Best way to use VI Drums eg SSD4, Superior Drummer Raoul23 The Drum Room 13 08-17-2012 10:04 PM
SSD4 Platinum for sale Jimibrix Windows 3 03-11-2012 07:20 PM
