Old 08-31-2005, 10:12 AM
Ian-H Ian-H is offline
Default Getting MIDI patch files working
Can someone help me get midi patch files working on PT6.4 LE. Loaded the midnam file, set up the JV2080 as a midi device (or tried to) under midi studio setup, but when I try and change the patch name and select the JV2080 midnam file nothing happens.
Are there some special tricks here?
Thanks, Ian
>> www.ianhenderson.co.za
G5-quad/4.5GB/10.4.3/LE 7.cs2/250GB sys/320GB audio
Old 08-31-2005, 10:14 AM
Default Re: Getting MIDI patch files working
Oh, and BTW, the JV2080 has its midi-in port connected to the midi-out port 1 on a Midisport 4x4 (which is working perfectly for a BCF2000) and the midi-out port connected to midi-in port 1 on the same 4x4.
Old 09-01-2005, 02:07 AM
Is anyone else going through this problem? I've set up my JV-2080 in Audio-Midi setup, but every time I try to select it under the "Change patch" option I get the error message: "ProTools could not find the appropriate patch names in the currently selected patch name document because either manufacturer/model information or instrument mode do not match".
Should I be able to set up the JV-2080 so that I can select it under the "output" for the midi track? Right now all I can see is the midi ports on the Midiman 4x4 midi hub, and the I suggest select the right port - output 1 - I don't see a way to set up the JV2080 so that I can select it from the output section.
Help - this is all looking very cryptic!
Old 09-01-2005, 02:18 AM
OK, wait a minute... twisted and convoluted workings have finally sorted this problem out. Digi's manuals need a serious upgrade in this area....
cheers - Ian
Old 09-01-2005, 05:38 AM
Alex Rodriguez Alex Rodriguez is offline
cheers - Ian
What was the solution anyway?
MacBook Pro 2.16 GHz Intel Core Duo, 2 GB of RAM, OS 10.4.11, PT 7.3.1
JV2080 midi patch files Ian-H 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 08-31-2018 02:09 PM
midi patch files problems help please??? doopman Pro Tools M-Powered (Mac) 2 09-17-2007 11:03 PM
MIDI server patch files not available Nick Batzdorf MIDI 5 03-29-2007 05:52 PM
Midi Device files for patch name files spkguitar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-04-2005 10:29 AM
Looking for MIDI PATCH NAMES FILES... fikafer Pro Tools TDM Systems (Mac) 7 01-24-2005 11:52 AM
